I am trying to simulate a 5.4 MeV alpha particle shooting at a 50 micron thick Kapton sheet sandwiched between a pair of 5 micron thick copper sheets. The source of the alpha particles is 1 mm in front of the front edge of the copper and the intervening region is filled with air. In the results shown below Shape 2 is the front copper sheet and Shape 3 is the Kapton sheet.
The simulation is based on a modification of the detector construction code of example B1. When I run the simulation the alpha particle loses about 100 keV in the first 1 mm through ionization of the air, which seems reasonable.
But I don’t understand what is going on when it enters the copper. Shown below are examples from a couple of events. Why does the particle lose about 2 MeV when entering the Kapton and why is all the remaining energy lost in a single ionization in the Kapton? Have I mis-applied the model?
* G4Track Information: Particle = alpha, Track ID = 1, Parent ID = 0
Step# X(mm) Y(mm) Z(mm) KinE(MeV) dE(MeV) StepLeng TrackLeng NextVolume ProcName
0 0 0 -51 5.4 0 0 0 Envelope initStep
1 0 0 -51 5.4 5.49e-05 0.000429 0.000429 Envelope ionIoni
2 -9.93e-07 1.7e-07 -51 5.39 0.00751 0.0635 0.064 Envelope ionIoni
3 -2.59e-05 -7.55e-07 -50.9 5.38 0.00609 0.0588 0.123 Envelope ionIoni
4 -2.25e-05 1.17e-06 -50.9 5.38 0.00116 0.0173 0.14 Envelope ionIoni
5 8.99e-06 1.53e-05 -50.8 5.37 0.0074 0.0783 0.218 Envelope ionIoni
6 6.63e-05 8.5e-05 -50.7 5.36 0.00955 0.112 0.33 Envelope ionIoni
7 7.19e-05 0.000101 -50.7 5.36 0.00173 0.0237 0.354 Envelope ionIoni
8 7.05e-05 0.000174 -50.6 5.35 0.0082 0.118 0.472 Envelope ionIoni
9 -6.63e-05 0.000185 -50.3 5.33 0.0213 0.248 0.719 Envelope ionIoni
10 -0.000108 0.000219 -50.2 5.32 0.00324 0.0625 0.782 Envelope ionIoni
11 -0.000116 0.000236 -50.2 5.32 0.00029 0.0121 0.794 Envelope ionIoni
12 -0.000129 0.000255 -50.2 5.32 0.000851 0.0171 0.811 Envelope ionIoni
13 -0.000235 0.000382 -50.1 5.3 0.0102 0.113 0.924 Envelope ionIoni
14 -0.00016 0.000341 -50.1 5.3 0.000956 0.0191 0.943 Envelope ionIoni
15 9.95e-05 0.000222 -50 5.3 0.00416 0.057 1 Shape2 Transportation
16 0.000119 0.00021 -50 3.19 2.1 0.00501 1.01 Shape3 Transportation
17 -0.000267 -0.00173 -50 0 3.19 0.0135 1.02 Shape3 ionIoni
1 0 0 -51 5.4 0.000372 0.0119 0.0119 Envelope ionIoni
2 -4.91e-07 3.6e-06 -50.8 5.38 0.0125 0.173 0.185 Envelope ionIoni
3 6.84e-06 9.24e-06 -50.8 5.38 0.00413 0.0404 0.225 Envelope ionIoni
4 0.00011 -9.72e-05 -50.4 5.34 0.0336 0.393 0.618 Envelope ionIoni
5 0.000115 0.000133 -50.2 5.32 0.023 0.231 0.849 Envelope ionIoni
6 2.52e-05 0.000411 -50 5.31 0.00909 0.151 1 Shape2 Transportation
7 2.06e-05 0.000418 -50 3.24 2.07 0.00501 1.01 Shape3 Transportation
8 -0.000129 0.00014 -50 0 3.24 0.0138 1.02 Shape3 ionIoni
