How should I compile in Release mode because the procedure that I follow build in Debug mode?
Should I rebuild the whole Geant4 from scratch?
I tried this for example B2a but it didn’t work
Geant4 version Name: geant4-11-01 [MT] (9-December-2022)
<< in Multi-threaded mode >>
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
Registering graphics systems…
ou have successfully registered the following graphics systems.
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
G4HepRepFile (HepRepFile)
RayTracer (RayTracer)
VRML2FILE (VRML2FILE)
gMocrenFile (gMocrenFile)
OpenGLImmediateWin32 (OGLIWin32, OGLI)
OpenGLStoredWin32 (OGLSWin32, OGL, OGLS)
TOOLSSG_WINDOWS_GLES (TSG_WINDOWS_GLES, TSG)
Registering model factories…
ou have successfully registered the following model factories.
Registered model factories:
generic
drawByAttribute
drawByCharge
drawByOriginVolume
drawByParticleID
drawByEncounteredVolume
egistered models:
None
Registered filter factories:
attributeFilter
chargeFilter
originVolumeFilter
particleFilter
encounteredVolumeFilter
egistered filters:
None
/vis/list" to see available colours.
ERROR: Can not open a macro file <init_vis.mac>. Set macro path with “/control/macroPath” if needed.
------- WWWW ------- G4Exception-START -------- WWWW -------
** G4Exception : UIMAN0123
ommand aborted (400)
rror code : 400
** This is just a warning message. ***
------- WWWW -------- G4Exception-END --------- WWWW -------
This is the output I got on recompiling again example B1
This says it could not find the macro file ‘init_vis.mac’.
Is the executable in the same folder as ‘init_vis.mac’?
Best regards
Max
yep! it is in the same folder
Apologies, as the example expects the macro to be in the current working directory, this should have been:
> cd ./Release
> ./exampleB1
Sorry for causing this much trouble. But it didn’t work. I’ve to manually open the file to get the visualization.
What do you mean by “manually open the file to get the visualisation”? What commands did you type, or what actions did you take, and what error messages, if any, did you see?
Thanku @bmorgan and everyone for the help.
Everything is working fine now. I would not be able to do this without your help. Thanku again for the help.
