mkelsey and John,
I think the procedure for installing GEANT4, found here:
is confusing when it comes to the build options part. Maybe I am making harder than it is, but it is not clear to me in which directory the build options should be turned on, what command should be used, etc.
I therefore tried what John suggested in the geant4…-build directory. This is what happened.
Jamess-MacBook-Pro:~ jamesbowen$ cd geant4-v11.0.0-build/
Jamess-MacBook-Pro:geant4-v11.0.0-build jamesbowen$ cmake -DGEANT4_USE_OPENGL_X11=ON
CMake Warning:
No source or binary directory provided. Both will be assumed to be the
same as the current working directory, but note that this warning will
become a fatal error in future CMake releases.
CMake Error: The source directory “/Users/jamesbowen/geant4-v11.0.0-build” does not appear to contain CMakeLists.txt.
Specify --help for usage, or press the help button on the CMake GUI.
I then went into the source directory that is inside the build directory and tried again…same thing happened. Is there anything else I need here?
From what I gather, I also need to go through the build and install process again after doing this. Is that correct?
