Using probability distribution to generate neutrons with random selection
Hi Christian,
What if you store all the distributions in separate files and let the energy and angles being sampled via those files in a macro? If yes, see my response here.. This is implemented via GPS, which I highly suggest as it is straightforward to implement.
With ParticleGun I have always generated random numbers from 0 to 1 and defined the angular range using those numbers. For example, for each event a random number is sampled, hence a random angle.
