2 ASCII STL files are not recognized as ASCII but are recognized individually
I have the following problem: I have implemented an ASCII STL file in my project. I then implemented another ASCII STL file in the same way. If I then comment out the first one, it works without any problems. The problem is that I want to implement both at the same time. Then I get the error (from Geant4) ; “Error around line 1: STL files start with ‘solid’. Make sure you are using an ASCII STL file.” The formats are correct, they worked wonderfully on their own. Does anyone know what to do?
Translated with DeepL.com (free version)
_Geant4 Version: 11.3.0
_Operating System: Linux MINT
_Compiler/Version:_13.3.0
_CMake Version:_cmake version 3.28.3
