Geant4 Version: 10.7.4
Operating System: Ubuntu 22.04/CentOS 7
Compiler/Version: gcc 11.4.0/gcc 7.3.1
CMake Version: 3.22.1/3.17.5
Hello, I am trying to simulate a deuteron beam (+1 charge state) impinging on a deuterium gas filled cell, and I’m having some difficulty in getting the correct neutron yield as a function of theta. Currently, I’m getting a large amount of rear-peaked neutrons, which isn’t making much sense as this reaction shows a large forward peak and I would expect most neutrons to be there (based on diff. cross sections from https://www-nds.iaea.org/public/libraries/drosg2000/). I only care about the measuring the produced neutrons in a detector. I’m stuck with 10.7.4 because I do not control the CentOS machine and I use it to run large batch jobs.
I’m currently using a custom physics list with QGSP_BIC_All_HP and G4IonPhysicsPHP. I’ve tried different things for Hadron Elastic physics as well to no avail (HP,PHP, and LEND). No difference was observed between using the G4NDL and ENDFVIII libraries. I can provide any code snippets needed, as well as any configuration files, if that would be helpful.
I’m stumped. I’m not sure what I need to change to make this work correctly.
Thanks
