Hi:
I recently needed to calculate dose
when extracting data, and I got the Mass of SD through the GetMass()
function.
i added a variable named boxmass
and a function named Getboxmass
to DetectorConstruction
. In DetectorConstruction::DefineVolumes
. I use the GetMass()
function by using it on the TinyboxLV
logical body and assign the obtained value to boxmass
. here is my code.
auto TinyboxS = new G4Box("TinyBoxS",0.5*cm,0.5*cm,0.5*cm);
auto TinyboxLV = new G4LogicalVolume(TinyboxS,Water_mat,"TinyboxLV");
G4VPVParameterisation* cellParam = new CellParameterisation();
new G4PVParameterised("Tinybox",TinyboxLV,waterboxLV,kZAxis,kNofTinybox,cellParam);
boxmass = TinyboxLV->GetMass();
G4double Getboxmass(){
return boxmass;
Because I am in EventAction: : EndOfEventAction
will fill data into tuples, so I need to get the probe’s molar mass . Here is my code.
void EventAction::EndOfEventAction(const G4Event* event){
DetectorConstruction*dect = new DetectorConstruction;
mass = dect->Getboxmass();
analysisManager->FillNtupleDColumn(4,(boxHit->GetEdep())/mass);
But I found a strange problem when running it. When I got the mole mass through GetMass()
in DetectorConstruction
, I output it once, and the value is 6.24151e+21
. When I get the molar mass from the Getboxmass
I wrote in EndOfEventAction
and output it, I find that the value is 0. Also, when I filled the tuple, I expected to get an error become mass=0, but it didn’t. I did the math based on the output and got mass=0.0078.
The object I’m probing is made of water, which seems strange, and I don’t know what’s wrong with me. Thank you for your messages.
