A Spherical Parameterisation for the Community
Hi folks,
On a couple of occasions previously (here, and here) I have noticed Geant4 users with questions regarding how to create a spherical shell detector (i.e. a sphere with radial, phi, and theta slices) such that users can detect and score quantities in a spherical coordinate system.
To help them with that I decided to put together a G4VPVParameterisation class, which should accomplish the behavior they are looking for. I hope you’ll find the class user-friendly because:
1.) How to use the parameterisation is explained, both in the readme and attached example program.
2.) The parameterisation performs error checking. It automatically determines the number of copies for the parameterisation and verifies that not too many copies have been placed. It also verifies that the given radial, phi, and theta segments tile the sphere evenly without any voxels being cut off.
3.) The parameterisation includes an attached function which will iterate through all of the copyNumbers and tell you explicitly the geometric properties of each slice for validation and debugging.
You can find the parameterisation here:
Best,
Joseph
Hello @JDecunha!
I am currently working with spherical parametrisation and your solution is very useful for me! Thank you for your work!
However I think I’ve found some mistakes or miscalculations.
In “SphericalParameterisation.cc” line 103 one needs to change
sphere.SetStartThetaAngle(thetaNum*_phiSegmentDegrees+_startPhi);
to
sphere.SetStartThetaAngle(thetaNum*_thetaSegmentDegrees+_startTheta);
because the theta angle is discussed.
And in line 91
G4int phiNum = copyNo - (copyNo/(_thetaIncrements*_phiIncrements))*_thetaIncrements *_phiIncrements;
the formula doesn’t work for most angles.
I can suggest that
will be better. Atleast, this works well for me.
I hope this will be helpful for some people. Also I assume I can be mistaken and my “corrections” are wrong.
Andrey
Hi @LavrikovA,
You were absolutely right to point out that there were issues with the parameterisation logic. I have modified it accordingly and done further verification to confirm it is working correctly. The GitHub project has been updated with the corrections. Previously, I (foolishly) tested with the phi and delta segments being the same size which is why I missed the error.
Thank you very much,
Joseph DeCunha
