I am new to Geant and running it in Windows 10 with Visual Studio 2017, CMake 3.14.4, . As far as I can tell, I have been able to successfully install Geant4 10.5 with OpenGL visualization and a multi-threaded build (In that, when using the instructions here as a guideline, the build did not yield any errors throughout the entire process.) I have also set all the necessary environment variables (including the path) and double and triple checked to make sure they are all set correctly.
However, when I try to run example B1 (following instructions on the same site on which I found the installation instructions) I continue to get the abort error shown in the screenshot/attachment below. The command prompt output I get is:
Geant4 version Name: geant4-10-05-patch-01 [MT] (17-April-2019)
<< in Multi-threaded mode >>
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
I’ve tried reinstalling a few times and thoroughly combed the old forum archives to no avail. Any suggestions on how to fix this?
