About two slightly different Geant4 installations
Hello, I have seen two Geant4 installation tutorials that are slightly different from each other. The part of the Geant4 installation I am referring to is when Visual Studio 2022 is used. Below I list the Geant4 installation steps from each of the tutorials: In one tutorial the steps are:
1.- Open Visual Studio 2022
2.- Open the Geant4.sln file
3.- At the top of the Visual Studio options menu, select Release
4.- In the Solution Explorer, select INSTALL
5.- Right click on INSTALL and select Build
6.- Wait an hour or more
On the other hand, in another Geant4 installation tutorial the steps are:
3.- At the top of the Visual Studio options menu select Release
4.- In the Solution Explorer, select ALL BUILD
5.- Right click on ALL BUILD and select Build
6.- After waiting several minutes, select INSTALL
7.- Right click on INSTALL and select Build
It should be added that I have installed Geant4 following the first series of steps that I have described. Can I continue working with Geant4 in this way or do I have to reinstall Geant4 following the second series of steps that I have described?
_Geant4 Version:_11.2.1
_Operating System:_Windows 10
_Compiler/Version:_Visual Studio 2022
_CMake Version:_3.29.0-rc2
They should be identical from the perspective of installing Geant4. In the first, the INSTALL step will actually perform the ALL BUILD/Build step as it depends on this happening first. So no, you don’t need to reinstall.
See also the official install guide for Windows.
Thank you for solving my doubt Doctor
