have recently started working with particle Detector Simulation and need some help in c++ and xml
Actually I have a Direct Photon Calorimeter (LumiDirectPCAL) and I need to place a 5cm carbon filter at a distance of 5-10 cm from the detector.
There is cpp file and an xml file. Cpp file created this detector volume which is a cube of 10cm. I need to add a filter in the same file so that It can be placed in front of the Detector.
Your help will be high appreciated.
codes are as follows:
- XML FILE
and cpp file is:
// SPDX-License-Identifier: LGPL-3.0-or-later
// Copyright (C) 2022 Anna Kowalewska
#include “DD4hep/DetFactoryHelper.h”
#include “DD4hep/Printout.h”
#include “DD4hep/Shapes.h”
#include “DDRec/DetectorData.h”
#include “DDRec/Surface.h”
#include “XML/Layering.h”
#include <XML/Helper.h>
using namespace std;
using namespace dd4hep;
static Ref_t create_detector(Detector& description, xml_h e, SensitiveDetector sens)
sens.setType(“calorimeter”);
xml_det_t x_det = e;
xml_comp_t x_dim = x_det.dimensions();
xml_comp_t x_pos = x_det.position();
xml_comp_t x_rot = x_det.rotation();
string det_name = x_det.nameStr();
string mat_name = dd4hep::getAttrOrDefault( x_det, _U(material), “PbWO4” );
string filterMat = dd4hep::getAttrOrDefault( x_det, _U(material), “Graphite” );
double sizeX = x_dim.x();
double sizeY = x_dim.y();
double sizeZ = x_dim.z();
double posX = x_pos.x();
double posY = x_pos.y();
double posZ = x_pos.z();
double rotX = x_rot.x();
double rotY = x_rot.y();
double rotZ = x_rot.z();
//auto filterVis = desc.visAttributes(filterElem.attrstd::string(_Unicode(vis)));
Box box( sizeX, sizeY, sizeZ );
Volume vol( det_name + “_vol”, box, description.material( mat_name ) );
vol.setVisAttributes( x_det.visStr() );
Transform3D pos( RotationZYX(rotX, rotY, rotZ), Position(posX, posY, posZ) );
DetElement det(det_name, x_det.id());
Volume motherVol = description.pickMotherVolume( det );
PlacedVolume phv = motherVol.placeVolume( vol, pos );
det.setPlacement(phv);
// - filter
double filterThickness = 5*cm;
Box filterSolid(sizeX, sizeY, filterThickness );
Volume filterVol(det_name + “_filter”, filterMat);
filterVol.setVisAttributes(x_det.visStr());
Transform3D filter_pos( RotationZYX(rotX, rotY, rotZ), Position(posX, posY, posZ) ); //need to set its position
DetElement filterDE(det, “filter_de”, 0);
//Volume vol = description.pickFilterVolume( filterDE );
//PlacedVolume filterPV = vol.placeVolume( filterVol, filter_pos );
//filterDE.setPlacement(filterPV);
return det;
DECLARE_DETELEMENT(LumiDirectPCAL, create_detector)
