Adjust/limit/specify beam angle
I want to specify the beam angle at about 70 ° like this:
But I don’t know how. So far, my code looks like:
G4double focus_size = 0.005*mm;
G4double x0 =  focus_size * (G4UniformRand()+4.0);
G4double y0 =  focus_size * (G4UniformRand()+4.0);
G4double z0 = 0.00025 * (G4UniformRand() -0.5);
G4ThreeVector orient(x0, y0, z0);
fParticleGun->SetParticleMomentumDirection(orient);
and produces this angle (I don’t know in numbers):
beam_angle
Any help is appreciated!
You may want to use G4ThreeVector G4RandomDirection(G4double cosTheta). It is defined in G4RandomDirection.h
Thanks a lot! Unfortunately, I can’t figure out how to use it. Geant4: G4RandomDirection.hh File Reference does not provide instructions or details, as far as I can see.
That’s why I tried to play around a bit:
With these lines of codes:
G4double cosTheta = 1;
G4ThreeVector G4RandomDirection(cosTheta);
fParticleGun->SetParticleMomentumDirection(G4RandomDirection);
However, the direction is always the same, whether I use G4double cosTheta = 1, G4double cosTheta = 20 or G4double cosTheta = 70.
Just realized that when I use values between [-1, 1] it’s changing then. But the angle is turning with the red-blue plane. I need an angle that is rotating on the green axis. It also seems that the angle is always fixed. Do I have to lay a random function over it to get an angle range?
G4RandomDirection(cosTheta) generates a random unit vector inside a cone around Z axis. Theta is the angle between Z axis and the surface of the cone. cosTheta should be in a range between [-1,1]. If to set cosTheta = 1, then all generated vectors will be directed alone Z.
Thanks a lot for clarifying!
Is there something similar for the axis y?
For example:
G4ThreeVector v = G4RandomDirection(cosTheta);
v.set(v.y(), v.z(), v.x());
Thanks again, but for
v.set(v.x(), v.z(), v.y());
and as well as for
v.set(v.x(), v.z(), v.y());|
I receive:
C:\geant4\sim\generator.cc(71,47): error C2440: ‘initializing’: cannot convert from ‘double’ to ‘CLHEP::Hep3Vector’ [C:\geant4\build\project.vcxproj]
No idea, there is a bug in line 71 of generator.cc. The code below
should work.
Have you included:
#include "G4RandomDirection.hh"
Thank you for your help! I really appreciate!
This is my generator.cc
#include “generator.hh”
#include “Randomize.hh”
#include “G4RandomDirection.hh”
MyPrimaryGenerator::MyPrimaryGenerator()
fParticleGun = new G4ParticleGun(1);
G4ParticleTable *particleTable = G4ParticleTable::GetParticleTable();
G4String particleName = “gamma”;
G4ParticleDefinition *particle = particleTable->FindParticle(“gamma”);
MyPrimaryGenerator::~MyPrimaryGenerator()
delete fParticleGun;
void MyPrimaryGenerator::GeneratePrimaries(G4Event *anEvent)
G4ThreeVector pos1(-53.66cm, -36cm - 1.8mm - 41.4cm, 0*m);
fParticleGun->SetParticlePosition(pos1);
G4double cosTheta = 0.75;
fParticleGun->SetParticleMomentum(0.1 *MeV);
which results in
C:\geant4\sim\generator.cc(74,62): error C2664: ‘void G4ParticleGun::SetParticleMomentumDirection(G4ParticleMomentum)’: cannot convert argument 1 from ‘overloaded-function’ to ‘G4ParticleMomentum’ [C:\geant4\bu
C:\geant4\sim\generator.cc(74,62): message : No constructor could take the source type, or constructor overload resolution was ambiguous [C:\geant4\build\project.vcxproj]
C:\Program Files\Geant4-11.0\include\Geant4\G4ParticleGun.hh(96,17): message : see declaration of ‘G4ParticleGun::SetParticleMomentumDirection’ [C:\geant4\build\project.vcxproj]
line 74 corresponds to:
and line 96 is the closing bracket
I realized that these two lines are working apparently and that there is an issue somewhere else when I try to use it for the particle direction. When I use
I won’t get an error. Obviously I’m not sure how to change/modify the axis and the particle direction then.
Could you please advice?
I think this should be written:
fParticleGun->SetParticleMomentumDirection(v);
G4RandomDirection is a function, not a variable.
I fully agree with the comment above. If you want to change the particle direction, then, in general case, you should apply a rotation transformation. But in case of simple change between axes, then it can be done by circular shift of the vector components:
(x,y,z) -> (z,x,y) -> (y,z,x)
BTW, a more clear way to specify the angle of the cone is:
G4double cosTheta = std::cos(70.*CLHEP::deg);
Hi bmorgan and evc,
thank you, changing the axis works now. Means, the beam cone refers to the y-axis now.
Next, I “only” need to rotate the cone itself such that 0° refers to the y-axis and e.g. 70° would be the angle segment beginning at this axis.
Is there a convenient command to do so?
edit: I figured it out. It would simply be:
v.rotateZ(70);
I’m having such a hard time to find solutions for all my problems because I still couldn’t figure out where to read up those things. I’m always googling around a lot and by coincidence I stumble over some things. But mostly I have to rely on this forum. I appreciate, a lot! But I would also like to become independent :slight_smile:
How do you guys do it? Where would have you looked up this command?
Hi evc,
I’m using
G4double cosTheta = std::cos(70*CLHEP::deg);
v.rotateZ(-35*CLHEP::deg);
now.
But it seems that the angle cone is much bigger than 70°. Almost likely 180°?
Instead, as bmorgan suggested
works correctly:
I figured out something else (resp. I wasn’t aware of before): The angle refers to the angle cone.
Is it doable to have no angle in z-direction? I only need a two-dimensional plane in xy with an angle of 70 °, not a three-dimensional cone of 70 °.
G4double cosTheta = std::cos(70*deg);
corresponds to the original image you posted
Ah, got it. So the total angle cone would be 140° then. Alright, thank you!
Is there a way to transform this three-dimensional cone into a two-dimensional plane (please see before)? Like a cone with z=0.
It can be easily done without G4RandomDirection():
G4double phi = 70*deg;
G4double a = 2*phi*G4UniformRand() + 90*deg - phi;
G4ThreeVector v(std::cos(a), std::sin(a), 0);
thank you very much!
I believe all my questions regarding this topic have been resolved :slight_smile:
