Again build Geant4
Geant4 Version: 11.3.2
Operating System: Sequoia 15.6.1
I have a problem that the Geant4 not stable, I downloaded it for many times for Mac. Now, again I try to download 11.3.0 again as it was on my lab before , try to download 11.3.1, try to download 11.3.2 to suit the operating system, but I get this issue after do make
[ 85%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/core/src/G4VBasicShell.cc.o
[ 85%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/core/src/G4VInteractiveSession.cc.o
[ 85%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/core/src/G4VInteractorManager.cc.o
[ 85%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/core/src/G4VUIshell.cc.o
[ 85%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/core/src/G4UItcsh.cc.o
[ 85%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/implementation/src/G4UIExecutive.cc.o
[ 85%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/implementation/src/G4UIQt.cc.o
[ 85%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/implementation/src/G4Qt.cc.o
[ 85%] Linking CXX shared library ../BuildProducts/lib/libG4interfaces.dylib
ld: framework ‘AGL’ not found
c++: error: linker command failed with exit code 1 (use -v to see invocation)
make[2]: *** [BuildProducts/lib/libG4interfaces.dylib] Error 1
make[1]: *** [source/CMakeFiles/G4interfaces.dir/all] Error 2
make: *** [all] Error 2
sarahabdelaziz@Sarahs-MacBook-Pro build-11.3.2 % brew
Could you help me to solve these errors, please?
Thanks!
@bmorgan
At first glance looks like something is trying to link AGL which I don’t think exists anymore in Sequoia. What version of QT is brew using? Has to be like QT6.5+. Or just disable it and open GL while building to see if that “solves” the issue.
how can I know which Qt is right to use, please?
If, as it seems, the home-brew install of Qt is being used, run
brew ls --versions qt
per this post on the Qt forum: ld: framework 'AGL' not found on macOS Tahoe | Qt Forum, anything higher than 6.8.4 should fix it. Homebrew currently installs 6.9.3, so you may need to run brew upgrade.
