I am simulating the radioactive decay for alpha particle dose estimations. I want to use the alpha particle filter in my simulation to score the dose only from the alpha particle, is there an alpha filter to do that? I have seen electrons, gammas filters but not the alpha filters! OR, if there is no alpha filter, do you suggest me to kill the electrons and gamma emissions generated from the decay mechnism to score only the alpha dose from the radioactive decay process? For these simulations, I am using the ion source using the particle gun command emitting isotropically. Any hints or suggestions are highly appreciated.
Yes, I tried that before - not sure why that was not working! I have just tried one more time but it seems working now. But the visualization displays all particles - how can we show only the filtered particle in visualization?
I think you need to issue the filtering line after each primitive scoret that you want to be filtered. in the macro you posted the dose would be unfiltered, but the deposited energy is filtered.
