I’m trying to write ntuples in my simulation, I’m using Geant4 11.0.0.
I’m working on CentOS stream 8 with gcc compiler 8.5.0.
I built Geant wit the following configuration:
> cmake3 -DCMAKE_INSTALL_PREFIX=/opt/Geant4/Geant4-11.0.0 ../geant4-v11.0.0/ -DGEANT4_USE_OPENGL_X11=ON -DGEANT4_USE_QT=ON -DGEANT4_USE_QT=ON -DGEANT4_INSTALL_DATA=ON -DGEANT4_BUILD_MULTITHREADED=true -DGEANT4_USE_GDML=ON
and I’m using ROOT from epel:
Version : 6.24.06
Release : 2.el8
Architecture : x86_64
Source : root-6.24.06-2.el8.src.rpm
Repository : @System
From repo : epel
the compilation error I get on AnaEx02 is the following:
Consolidate compiler generated dependencies of target AnaEx01
[ 33%] Built target AnaEx01
Consolidate compiler generated dependencies of target exampleB1Con
[ 66%] Built target exampleB1Con
Consolidate compiler generated dependencies of target AnaEx02
[ 70%] Building CXX object AnaEx02/CMakeFiles/AnaEx02.dir/src/HistoManager.cc.o
In file included from /usr/include/root/TString.h:29,
from /usr/include/root/TNamed.h:26,
from /usr/include/root/TAxis.h:24,
from /usr/include/root/TH1.h:24,
from /usr/include/root/TH1D.h:24,
from /home/stroili/tmp/Geant4/analysis/AnaEx02/src/HistoManager.cc:33:
/usr/include/root/ROOT/RStringView.hxx:32:84: error: conflicting declaration of template ‘template<class _CharT, class _Traits> using basic_string_view = std::experimental::fundamentals_v1::basic_string_view<_CharT, _Traits>’
using basic_string_view = ::std::experimental::basic_string_view<_CharT,_Traits>;
In file included from /usr/include/c++/8/bits/basic_string.h:48,
from /usr/include/c++/8/string:52,
from /usr/include/root/TSchemaHelper.h:17,
from /usr/include/root/TGenericClassInfo.h:21,
from /usr/include/root/Rtypes.h:191,
from /usr/include/root/TObject.h:17,
from /usr/include/root/TNamed.h:25,
/usr/include/c++/8/string_view:71:11: note: previous declaration ‘template<class _CharT, class _Traits> class std::basic_string_view’
class basic_string_view
In file included from /usr/include/c++/8/memory:74,
from /usr/include/root/ROOT/TypeTraits.hxx:15,
from /usr/include/root/TString.h:30,
/usr/include/c++/8/ext/concurrence.h:53:16: error: ‘_Lock_policy’ does not name a type
static const _Lock_policy __default_lock_policy =
In file included from /usr/include/c++/8/cstddef:49,
from /usr/include/root/RtypesCore.h:28,
from /usr/include/root/Rtypes.h:23,
/usr/include/c++/8/ext/concurrence.h: In function ‘void std::__throw_concurrence_lock_error()’:
/usr/include/c++/8/ext/concurrence.h:102:5: error: ‘__concurrence_lock_error’ was not declared in this scope
{ _GLIBCXX_THROW_OR_ABORT(__concurrence_lock_error()); }
/usr/include/c++/8/ext/concurrence.h:102:5: note: suggested alternative:
/usr/include/c++/8/ext/concurrence.h:67:9: note: ‘__gnu_cxx::__concurrence_lock_error’
class __concurrence_lock_error : public std::exception
/usr/include/c++/8/ext/concurrence.h: In function ‘void std::__throw_concurrence_unlock_error()’:
/usr/include/c++/8/ext/concurrence.h:106:5: error: ‘__concurrence_unlock_error’ was not declared in this scope
{ _GLIBCXX_THROW_OR_ABORT(__concurrence_unlock_error()); }
/usr/include/c++/8/ext/concurrence.h:106:5: note: suggested alternative:
/usr/include/c++/8/ext/concurrence.h:75:9: note: ‘__gnu_cxx::__concurrence_unlock_error’
class __concurrence_unlock_error : public std::exception
/usr/include/c++/8/ext/concurrence.h: In function ‘void std::__throw_concurrence_broadcast_error()’:
/usr/include/c++/8/ext/concurrence.h:111:5: error: ‘__concurrence_broadcast_error’ was not declared in this scope
{ _GLIBCXX_THROW_OR_ABORT(__concurrence_broadcast_error()); }
/usr/include/c++/8/ext/concurrence.h:111:5: note: suggested alternative:
/usr/include/c++/8/ext/concurrence.h:83:9: note: ‘__gnu_cxx::__concurrence_broadcast_error’
class __concurrence_broadcast_error : public std::exception
/usr/include/c++/8/ext/concurrence.h: In function ‘void std::__throw_concurrence_wait_error()’:
/usr/include/c++/8/ext/concurrence.h:115:5: error: ‘__concurrence_wait_error’ was not declared in this scope
{ _GLIBCXX_THROW_OR_ABORT(__concurrence_wait_error()); }
/usr/include/c++/8/ext/concurrence.h:115:5: note: suggested alternative:
/usr/include/c++/8/ext/concurrence.h:91:9: note: ‘__gnu_cxx::__concurrence_wait_error’
class __concurrence_wait_error : public std::exception
/usr/include/c++/8/ext/concurrence.h: In member function ‘void __gnu_cxx::__mutex::lock()’:
/usr/include/c++/8/ext/concurrence.h:153:6: error: ‘__throw_concurrence_lock_error’ was not declared in this scope
__throw_concurrence_lock_error();
/usr/include/c++/8/ext/concurrence.h:153:6: note: suggested alternative:
/usr/include/c++/8/ext/concurrence.h:101:3: note: ‘std::__throw_concurrence_lock_error’
/usr/include/c++/8/ext/concurrence.h: In member function ‘void __gnu_cxx::__mutex::unlock()’:
/usr/include/c++/8/ext/concurrence.h:164:6: error: ‘__throw_concurrence_unlock_error’ was not declared in this scope
__throw_concurrence_unlock_error();
/usr/include/c++/8/ext/concurrence.h:164:6: note: suggested alternative:
/usr/include/c++/8/ext/concurrence.h:105:3: note: ‘std::__throw_concurrence_unlock_error’
/usr/include/c++/8/ext/concurrence.h: In member function ‘void __gnu_cxx::__recursive_mutex::lock()’:
/usr/include/c++/8/ext/concurrence.h:208:6: error: ‘__throw_concurrence_lock_error’ was not declared in this scope
/usr/include/c++/8/ext/concurrence.h:208:6: note: suggested alternative:
/usr/include/c++/8/ext/concurrence.h: In member function ‘void __gnu_cxx::__recursive_mutex::unlock()’:
/usr/include/c++/8/ext/concurrence.h:219:6: error: ‘__throw_concurrence_unlock_error’ was not declared in this scope
/usr/include/c++/8/ext/concurrence.h:219:6: note: suggested alternative:
/usr/include/c++/8/ext/concurrence.h: At global scope:
/usr/include/c++/8/ext/concurrence.h:234:13: error: ‘__mutex’ does not name a type
typedef __mutex __mutex_type;
/usr/include/c++/8/ext/concurrence.h:237:5: error: ‘__mutex_type’ does not name a type; did you mean ‘__mutex’?
__mutex_type& _M_device;
__mutex
/usr/include/c++/8/ext/concurrence.h:243:40: error: expected ‘)’ before ‘&’ token
explicit __scoped_lock(__mutex_type& __name) : _M_device(__name)
/usr/include/c++/8/ext/concurrence.h: In destructor ‘__gnu_cxx::__scoped_lock::~__scoped_lock()’:
/usr/include/c++/8/ext/concurrence.h:247:7: error: ‘_M_device’ was not declared in this scope
{ _M_device.unlock(); }
/usr/include/c++/8/ext/concurrence.h:247:7: note: suggested alternative: ‘__dev_t’
__dev_t
/usr/include/c++/8/ext/concurrence.h:291:15: error: ‘__mutex’ has not been declared
void wait(__mutex *mutex)
/usr/include/c++/8/ext/concurrence.h:301:25: error: ‘__recursive_mutex’ has not been declared
void wait_recursive(__recursive_mutex *mutex)
/usr/include/c++/8/ext/concurrence.h: In member function ‘void __gnu_cxx::__cond::broadcast()’:
/usr/include/c++/8/ext/concurrence.h:286:6: error: ‘__throw_concurrence_broadcast_error’ was not declared in this scope
__throw_concurrence_broadcast_error();
/usr/include/c++/8/ext/concurrence.h:286:6: note: suggested alternative:
/usr/include/c++/8/ext/concurrence.h:110:3: note: ‘std::__throw_concurrence_broadcast_error’
and so on.
I get the same kind of behaviour on an old simulation I developed in G4 10.x and that was working.
Thank you for your help.
Roberto
