Any VTK examples?
_Geant4 Version:_4.11.1.0
_Operating System:_Linux Fedora
_Compiler/Version:_13.2.1
_CMake Version:_3.27.7
I don’t see any examples of the use of vtk visualization in the examples directory of geant4-11.1.0. Could someone please point me to one? Thanks.
There’s no specific example. Just build with Vtk (see Installation Guide), then you should be able to use Vtk (/vis/open Vtk)with any example or app.
Thanks, John. I will give it a try. I was under the impression that vtk has some additional functionalties, like saving the view in a file. I assume I will find something like export view as… in the menu. We’ll see.
Thanks again.
Ah, yes, Munther. I’m afraid I forgot. There is examples/extended/visualization/vtk but
Author: Stewart Boogert <stewart.boogert@cockcroft.ac.uk>
Date:   Sun Sep 17 17:02:45 2023 +0100
    vis vtk : added VTK example
which means only since 11.2.
Of course, once you build with Vtk, you get lots of nice commands. I recommend 11.2.
Ok, thanks. Downloaded v11.2.1 and now compiling. I do see the example examples/extended/visualization/vtk now. Getting a new geant version compiled with all the options I am used to is always a pain! Hopefully the vtk example will work. I will let you know.
Thanks,
Munther
I was to able to compile v11.2.1 and run the vtk example. Thanks!
