This is a guide to building a Geant4 singularity image file, as I did not find something similar online.
I used a container, as our old HPC has glibc 2.17. I needed G4 with GDML and xerces-c needs glibc 3.4 (install ‘succeeds’, but errors when making a G4 example).
As the data files are upgraded over time, you may need to update the versions in the definition ‘def’ file (in %environment).
Once built, run
apptainer exec geant4-11.3.0-alma.sif ls /opt/geant4/install/share/Geant4/data
then update the definition ‘def’ file with the correct datafile versions as necessary, rebuild.
The definition file geant4-11.3.0-alma.def is as below:
Bootstrap: docker
%post
# Install required packages
# Install development tools and dependencies
dnf group install -y "Development Tools"
dnf install -y \
epel-release
dnf install -y \
cmake \
expat-devel \
gcc-c++ \
make \
xerces-c-devel \
git \
wget
# Create installation directories
mkdir -p /opt/geant4/build
mkdir -p /opt/geant4/install
# Download and install Geant4
cd /opt/geant4
wget https://gitlab.cern.ch/geant4/geant4/-/archive/v11.3.0/geant4-v11.3.0.tar.gz
tar xzf geant4-v11.3.0.tar.gz
cd build
# Configure and build Geant4
cmake ../geant4-v11.3.0 \
-DCMAKE_INSTALL_PREFIX=/opt/geant4/install \
-DGEANT4_INSTALL_DATA=ON \
-DGEANT4_USE_GDML=ON \
-DGEANT4_USE_SYSTEM_EXPAT=ON \
-DGEANT4_BUILD_MULTITHREADED=ON
# Build and install
make -j$(nproc)
make install
# Cleanup
cd /opt/geant4
rm -rf build geant4-v11.3.0.tar.gz
rm -f /root/*.pkg.tar*
rm -f /root/*.tar.gz
%files
%environment
export PATH="/opt/geant4/install/bin:${PATH}"
export G4INSTALL="/opt/geant4/install"
export G4EXAMPLES="/opt/geant4/install/share/Geant4/examples"
export G4NEUTRONHPDATA="/opt/geant4/install/share/Geant4/data/G4NDL4.7.1"
export G4LEDATA="/opt/geant4/install/share/Geant4/data/G4EMLOW8.6.1"
export G4LEVELGAMMADATA="/opt/geant4/install/share/Geant4/data/PhotonEvaporation6.1"
export G4RADIOACTIVEDATA="/opt/geant4/install/share/Geant4/data/RadioactiveDecay6.1.2"
export G4PARTICLEXSDATA="/opt/geant4/install/share/Geant4/data/G4PARTICLEXS4.1"
export G4PIIDATA="/opt/geant4/install/share/Geant4/data/G4PII1.3"
export G4REALSURFACEDATA="/opt/geant4/install/share/Geant4/data/RealSurface2.2"
export G4SAIDXSDATA="/opt/geant4/install/share/Geant4/data/G4SAIDDATA2.0"
export G4ABLADATA="/opt/geant4/install/share/Geant4/data/G4ABLA3.3"
export G4INCLDATA="/opt/geant4/install/share/Geant4/data/G4INCL1.2"
export G4ENSDFSTATEDATA="/opt/geant4/install/share/Geant4/data/G4ENSDFSTATE3.0"
%runscript
exec "$@"
%help
Geant4-11.3.0-1
Built with system xerces-c for GDML support
To build:
sudo apptainer build geant4-11.3.0-alma.sif geant4-11.3.0-alma.def
Once built, you can test using an example:
apptainer exec geant4-11.3.0-alma.sif cp -r /opt/geant4/install/share/Geant4/examples .
cd examples/extended/electromagnetic/
mkdir TestEm1_build
cd TestEm1_build
apptainer exec geant4-11.3.0-alma.sif cmake ../TestEm1
apptainer exec geant4-11.3.0-alma.sif make TestEm1
apptainer exec geant4-11.3.0-alma.sif ./TestEm1 annihil.mac
Thanks to Simon Biggs.
