Assistance Required for GEANT4 Simulation of p(⁷Li, n)⁷Be Reaction
_Geant4 Version:_11.3.0
_Operating System:_ubuntu
_CMake Version:_3.28.3
Hello, I am currently working on a GEANT4 simulation for the inverse kinematic reaction p(⁷Li, n)⁷Be and have encountered some challenges that I would greatly appreciate your guidance on.
I have tested different combinations of reference physics lists, including G4HadronicPhysicsQGSP_BIC_AllHP, G4IonPhysicsPHP, and G4IonINCLXXPhysics, among others. However, the simulation yields counts only for ⁷Li energies up to 22 MeV, and beyond this energy, I do not observe any counts—even when simulating 10⁹ ⁷Li ions.
Comparing my results with prior published data for the direct kinematics reaction ⁷Li(p, n)⁷Be, I found that the cross-section data is available for proton energies up to 10 MeV. Simulating this reaction in GEANT4 produces results consistent with the expected cross-section. Since the center-of-mass (COM) cross-sections should be the same for both direct and inverse kinematics, I would expect to observe counts beyond 22 MeV in the inverse kinematics simulation, but this is not the case. Additionally, the simulated cross-section does not match the direct kinematics cross-section trend.
I am trying to simulate the p(⁷Li, n)⁷Be reaction at ⁷Li = 28 MeV. Given the limited experimental data for inverse kinematics, I am wondering if GEANT4 is not correctly handling the data for this reaction. Is there a possibility that GEANT4 does not correctly convert direct kinematics cross-sections into the COM frame for inverse kinematics? Could this issue be related to the physics list selection?
I would greatly appreciate any insights or suggestions on how to refine my simulation to obtain accurate results.
Looking forward to your response.
