Geant4 Version: 11.2.0
Operating System: MacOS 14.2
Just by changing the direction of the particle gun in basic/B2/Ba2 example I get a EXC_BAD_ACCESS crash.
diff --git a/examples/basic/B2/B2a/src/PrimaryGeneratorAction.cc b/examples/basic/B2/B2a/src/PrimaryGeneratorAction.cc
index bb87b9b08e..19ae7902db 100644
--- a/examples/basic/B2/B2a/src/PrimaryGeneratorAction.cc
+++ b/examples/basic/B2/B2a/src/PrimaryGeneratorAction.cc
@@ -55,7 +55,7 @@ PrimaryGeneratorAction::PrimaryGeneratorAction()
= G4ParticleTable::GetParticleTable()->FindParticle("proton");
fParticleGun->SetParticleDefinition(particleDefinition);
- fParticleGun->SetParticleMomentumDirection(G4ThreeVector(0.,0.,1.));
+ fParticleGun->SetParticleMomentumDirection(G4ThreeVector(0.,0.,-1.));
fParticleGun->SetParticleEnergy(3.0*GeV);
The trace back is:
* thread #2, stop reason = EXC_BAD_ACCESS (code=1, address=0x3b7f61480)
* frame #0: 0x0000000101491f98 libG4geometry.dylib`G4VPhysicalVolume::GetRotation() + 40
frame #1: 0x00000001014d1370 libG4geometry.dylib`G4VoxelNavigation::ComputeStep(CLHEP::Hep3Vector const&, CLHEP::Hep3Vector const&, double, double&, G4NavigationHistory&, bool&, CLHEP::Hep3Vector&, bool&, bool&, G4VPhysicalVolume**, int&) + 760
frame #2: 0x00000001014b2aec libG4geometry.dylib`G4Navigator::ComputeStep(CLHEP::Hep3Vector const&, CLHEP::Hep3Vector const&, double, double&) + 1080
frame #3: 0x000000010335e6d8 libG4processes.dylib`G4Transportation::AlongStepGetPhysicalInteractionLength(G4Track const&, double, double, double&, G4GPILSelection*) + 1080
frame #4: 0x0000000100c188b4 libG4tracking.dylib`G4SteppingManager::DefinePhysicalStepLength() + 600
frame #5: 0x0000000100c1822c libG4tracking.dylib`G4SteppingManager::Stepping() + 388
frame #6: 0x0000000100c2aeb8 libG4tracking.dylib`G4TrackingManager::ProcessOneTrack(G4Track*) + 872
frame #7: 0x0000000100b98afc libG4event.dylib`G4EventManager::DoProcessing(G4Event*) + 1888
frame #8: 0x0000000100e25410 libG4run.dylib`G4WorkerTaskRunManager::ProcessOneEvent(int) + 60
frame #9: 0x0000000100e25380 libG4run.dylib`G4WorkerTaskRunManager::DoEventLoop(int, char const*, int) + 232
frame #10: 0x0000000100e26bec libG4run.dylib`G4WorkerTaskRunManager::DoWork() + 408
frame #11: 0x0000000100e11b4c libG4run.dylib`std::__1::__packaged_task_func<std::__1::enable_if<std::is_void<void>::value, void>::type PTL::TaskGroup<void, void, 0l>::exec<G4TaskRunManager::AddEventTask(int)::$_4, void>(G4TaskRunManager::AddEventTask(int)::$_4)::'lambda'(), std::__1::allocator<std::__1::enable_if<std::is_void<void>::value, void>::type PTL::TaskGroup<void, vG4TaskRunManager::AddEventTask(int)::$_4)::'lambda'(), std::__1::allocator<std::__1::enable_if<std::is_void<void>::value, void>::type PTL::TaskGroup<void, void, 0l>::exec<G4TaskRunManager::AddEventTask(int)::$_4, void>(G4TaskRunManager::AddEventTask(int)::$_4)::'lambda'()>, void ()>::operator()() + 44
frame #12: 0x0000000100e11c28 libG4run.dylib`std::__1::packaged_task<void ()>::operator()() + 80
frame #13: 0x0000000100c5d668 libG4ptl.2.dylib`PTL::ThreadPool::execute_thread(PTL::VUserTaskQueue*) + 996
frame #14: 0x0000000100c5cda4 libG4ptl.2.dylib`PTL::ThreadPool::start_thread(PTL::ThreadPool*, std::__1::vector<std::__1::shared_ptr<PTL::ThreadData>, std::__1::allocator<std::__1::shared_ptr<PTL::ThreadData>>>*, long) + 688
frame #15: 0x0000000100c63afc libG4ptl.2.dylib`void* std::__1::__thread_proxy[abi:v160006]<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct>>, void (*)(PTL::ThreadPool*, std::__1::vector<std::__1::shared_ptr<PTL::ThreadData>, std::__1::allocator<std::__1::shared_ptr<PTL::ThreadData>>>*, long), PTL::ThreadPool*, std::__1::vector<std::__1::shared_ptr<PTL::ThreadData>, std::__1::allocator<std::__1::shared_ptr<PTL::ThreadData>>>*, unsigned long>>(void*) + 56
frame #16: 0x0000000185132034 libsystem_pthread.dylib`_pthread_start + 136
(lldb)
frame #11: 0x0000000100e11b4c libG4run.dylib`std::__1::__packaged_task_func<std::__1::enable_if<std::is_void<void>::value, void>::type PTL::TaskGroup<void, void, 0l>::exec<G4TaskRunManager::AddEventTask(int)::$_4, void>(G4TaskRunManager::AddEventTask(int)::$_4)::'lambda'(), std::__1::allocator<std::__1::enable_if<std::is_void<void>::value, void>::type PTL::TaskGroup<void, void, 0l>::exec<G4TaskRunManager::AddEventTask(int)::$_4, void>(G4TaskRunManager::AddEventTask(int)::$_4)::'lambda'()>, void ()>::operator()() + 44
