I’m investigating the creation of muon pairs from high energy brehms photons. To this end, I’ve constructed a simple setup, where I have a gun, a block of tungsten and some tracker planes. For additional information I store the creation vertices of muons and pions created inside my converter block with this code in SteppingAction.cc:
G4int PDG = aStep->GetTrack()->GetDefinition()->GetPDGEncoding();
if (abs(PDG)==13 || abs(PDG)==211)
if (aStep->GetTrack()->GetCurrentStepNumber()==1)
histoManager->FillMuonPionInfo(aStep, event, 0, proc->GetProcessType()*10000+proc->GetProcessSubType());
where the integer 0 is for my bookkeeping, the proc->GetProcessType()*10000+proc->GetProcessSubType()) value gives me the process and its subtype in one integer and the corresponding function in histoManager is
void HistoManager::FillMuonPionInfo(const G4Step* aStep, G4int event, G4int status, G4int creationProcess)
auto fAnalysisManager = G4AnalysisManager::Instance();
//Fill the NTuple
fAnalysisManager->FillNtupleIColumn(0, 0, aStep->GetTrack()->GetDefinition()->GetPDGEncoding());
fAnalysisManager->FillNtupleIColumn(0, 1, event);
fAnalysisManager->FillNtupleIColumn(0, 2, status);
fAnalysisManager->FillNtupleIColumn(0, 3, aStep->GetTrack()->GetCurrentStepNumber());
fAnalysisManager->FillNtupleIColumn(0, 4, creationProcess);
auto stepPoint = aStep->GetTrack()->GetStep()->GetPreStepPoint();
fAnalysisManager->FillNtupleDColumn(0, 5, stepPoint->GetGlobalTime());
fAnalysisManager->FillNtupleDColumn(0, 6, aStep->GetTrack()->GetTotalEnergy());
fAnalysisManager->FillNtupleDColumn(0, 7, stepPoint->GetMomentumDirection().x());
fAnalysisManager->FillNtupleDColumn(0, 8, stepPoint->GetMomentumDirection().y());
fAnalysisManager->FillNtupleDColumn(0, 9, stepPoint->GetMomentumDirection().z());
fAnalysisManager->FillNtupleDColumn(0, 10, stepPoint->GetPosition().x());
fAnalysisManager->FillNtupleDColumn(0, 11, stepPoint->GetPosition().y());
fAnalysisManager->FillNtupleDColumn(0, 12, stepPoint->GetPosition().z());
fAnalysisManager->AddNtupleRow(0);
if ((status == 0) and (abs(aStep->GetTrack()->GetDefinition()->GetPDGEncoding()) == 13))
createdMuonCount++;
The code uses QGSP_BERT physics list and I enable muon creation in my macro file, pre-init with /physics_lists/em/GammaToMuons true.
The problem I encountered when moving from 11.0.4 to 11.1.1 is that the results are very, very different:
The sim results above are for 1e7 events, with cross section for muon creation enhanced by a factor of 1000.
The only difference between the results is compiling my code against GEANT4 v11.1.1 and v11.0.4!!! Has anyone an idea what was changed to create such large differences? If it helps, the warning
G4GammaConversionToMuons::PostStepDoIt WARNING: in dSigxPlusGen, result=3.27683 > 1 is shown a lot more often when running the v11.1.1 code.
Any help is greatly appreciated! I’m stumped and would like to know which results I can trust ![]()
Kris
