Build in Visual Studio not successfull
First of all, thanks for the immediate help. I’ve run through the process with the geant4 10_05 version and as you suggested, there was no access to certain folders as the required data somehow was stored in subfolders. Simply copy and paste those folders to the right destination fixed the issue for me.
After that i’ve been trying to make the B1 example work in release mode, successfully. However, as i am interested in debugging the B1 example i would like to make it work on debug mode. Building geant4 10_05 in debug mode results in linker errors (see Errors when trying to build Geant4) and building the B1 example results in an exception.
Is it possible to build geant4 and its examples in debug mode?
