Hi all,
I am trying to load CAD files into GEANT4 through the CADMESH from GitHub - christopherpoole/CADMesh: A CAD file interface for GEANT4.
I converted my .step file to a .ply format. The code is running without any error in the beginning and then when I tried to open the geometry with the Qt visualization program an error appeared and I cannot see the geometry.
*** G4Exception : LexerError
issued by : CADMesh in Lexer
The CAD file appears to contain incorrect syntax:
Error around line 1: PLY files start with ‘ply’.
I tried to convert my .step file to .obj format since I thought that probably something went wrong with the .ply transformation but again a different error appeared when I tried to see the geometry in the qt program.
*** G4Exception : MeshNotFound
issued by : CADMesh in Reader::GetMesh
The mesh with index ‘0’ could not be found.
Could someone help me with the above errors?
Thank you very much for your help.
