Can anyone please guide me, how can I import stp file in geant4?
Take a look at
examples/extended/persistency/gdml/G02
It shows how to write and read GDML-files and how to read stp-files.
For this Geant4 needs to be compiled with GDML, which requires the Xerces-C library.
otherwise i recommend
CADMesh: A CAD file interface for GEANT4
which provides an example how to use it and read stp-files.
Regards
Max
No way to import STEP directly. You can try pyg4ometry or FreeCAD GDML plugin (environment, see docs therein)
uhm… could you specify what you mean?
I posted two ways how to directly import STEP-files…
The first solution i posted is an offical Geant4-Example which says in its README
“In this directory you can find a example showing how to use GDML module for
reading and writing. It is also shown how to Read STEP Tools files.”
You dont need to convert your stp-files to import them into Geant4.
Do you mean CAD-files?
EDIT: I was already one step ahead in my mind…
yeah, you CANT import STEP-files (STandard for the Exchange of Product model data) which originate from a CAD Tool like Inventor, Fusion360 or FreeCAD BUT you can use these tools to convert a .stp-file to a .stl-file (Standard Tessellation Language) and load these into Geant4 with the above mentioned methods at the cost of tesselating your geometry.
Yes. A STEP flie from CAD starts with
ISO-10303-21;
HEADER;
/* Generated by software containing ST-Developer
 * from STEP Tools, Inc. (www.steptools.com)
Second, STL files are not assembly files but single-piece volumes, which demand significant work to prepare complex geometry with heterogeneous parts.
