Geant4 Version: v11.2.2
Operating System: OSX Sonoma 14.5
Compiler/Version: Apple clang version 15.0.0
CMake Version: 3.29.2
I have downloaded compiled and install Geant4 with these cmake flags:
cmake -DCMAKE_INSTALL_PREFIX=MyPathToInstall -DGEANT4_INSTALL_DATA=ON -DGEANT4_USE_GDML=ON -DCMAKE_BUILD_TYPE=Debug -DGEANT4_USE_OPENGL_X11=ON -DGEANT4_USE_QT=ON -DGEANT4_USE_GDML=ON MyPathToSource
and everything works ok. Applications compile OK (tried on basic examples), but when I run them I dont get the visualisation and get the following exception:
WARNING: G4VisCommandSceneHandlerCreate::SetNewValue:
Using fallback graphics system: OpenGLStoredX (OGLSX)
G4OpenGLXViewer::G4OpenGLXViewer: unable to get a single buffer visual.
G4OpenGLXViewer::G4OpenGLXViewer: unable to get a double buffer visual.
G4OpenGLXViewer::G4OpenGLXViewer: unable to get required visuals.
G4OpenGLStoredX::CreateViewer: error flagged by negative view id in G4OpenGLStoredXViewer creation.
Destroying view and returning null pointer.
ERROR in G4VisManager::CreateViewer: null pointer during OpenGLStoredX viewer creation.
No action taken.
*** G4Exception : UIMAN0123
WARNING: No viewer created.
Error code : 1
sub-command “/vis/viewer/create” failed.
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
G4HepRepFile (HepRepFile)
RayTracer (RayTracer)
VRML2FILE (VRML2FILE)
gMocrenFile (gMocrenFile)
OpenGLImmediateX (OGLIX, OGLIQt_FALLBACK)
OpenGLStoredX (OGLSX, OGLSQt_FALLBACK)
Qt3D (Qt3D)
TOOLSSG_X11_GLES (TSG_X11_GLES, TSGX11, TSG_QT_GLES_FALLBACK)
TOOLSSG_QT_GLES (TSG_QT_GLES, TSGQt, TSG)
TOOLSSG_QT_ZB (TSG_QT_ZB, TSGQtZB)
Default graphics system is: OGL (based on build flags).
Use “vis/open” without parameters to get these defaults.
Invoked command has failed - see above.
Error code : 1
***** Illegal parameter (1) </vis/open> *****
Command aborted (1)
Error code : 1
***** Illegal parameter (1) </control/execute vis.mac> *****
Command aborted (1)
Error code : 1
Can anyone provide any input on what I am doing wrong? I have al the prerequisites installed.
