I have a simple geometry, an aluminum sphere of the thickness of 3 mm with Si detector inside it.
QBBC physics list is used and Geant4 10.5 p1 version.
Source particle is Al27 with spectrum bellow:
/gps/particle ion
/gps/ion 13 27
/gps/ene/type Arb
/gps/hist/type arb
/gps/hist/point 2.700000E+01 8.056426E-11
/gps/hist/point 2.970000E+01 9.837457E-11
/gps/hist/point 3.240000E+01 1.178625E-10
/gps/hist/point 3.780000E+01 1.617166E-10
/gps/hist/point 4.320000E+01 2.117936E-10
/gps/hist/point 4.860000E+01 2.678019E-10
/gps/hist/point 5.400000E+01 3.294400E-10
/gps/hist/point 5.940000E+01 3.964187E-10
/gps/hist/point 6.750000E+01 5.063368E-10
/gps/hist/point 7.560000E+01 6.268482E-10
/gps/hist/point 8.640000E+01 8.026518E-10
/gps/hist/point 9.450000E+01 9.449659E-10
/gps/hist/point 1.080000E+02 1.200227E-09
/gps/hist/point 1.215000E+02 1.475795E-09
/gps/hist/point 1.350000E+02 1.769596E-09
/gps/hist/point 1.485000E+02 2.079483E-09
/gps/hist/point 1.701000E+02 2.604506E-09
/gps/hist/point 1.917000E+02 3.160442E-09
/gps/hist/point 2.160000E+02 3.816407E-09
/gps/hist/point 2.430000E+02 4.576295E-09
/gps/hist/point 2.700000E+02 5.362447E-09
/gps/hist/point 2.970000E+02 6.169083E-09
/gps/hist/point 3.240000E+02 6.991803E-09
/gps/hist/point 3.780000E+02 8.670293E-09
/gps/hist/point 4.320000E+02 1.037379E-08
/gps/hist/point 4.860000E+02 1.208470E-08
/gps/hist/point 5.400000E+02 1.379033E-08
/gps/hist/point 5.940000E+02 1.548051E-08
/gps/hist/point 6.750000E+02 1.797117E-08
/gps/hist/point 7.560000E+02 2.039396E-08
/gps/hist/point 8.640000E+02 2.350163E-08
/gps/hist/point 9.450000E+02 2.573090E-08
/gps/hist/point 1.080000E+03 2.946688E-08
/gps/hist/point 1.215000E+03 3.340393E-08
/gps/hist/point 1.350000E+03 3.737364E-08
/gps/hist/point 1.485000E+03 4.098145E-08
/gps/hist/point 1.701000E+03 4.602810E-08
/gps/hist/point 1.917000E+03 5.061860E-08
/gps/hist/point 2.160000E+03 5.525936E-08
/gps/hist/point 2.430000E+03 5.975937E-08
/gps/hist/point 2.700000E+03 6.389120E-08
/gps/hist/point 2.970000E+03 6.754424E-08
/gps/hist/point 3.240000E+03 7.069463E-08
/gps/hist/point 3.780000E+03 7.517705E-08
/gps/hist/point 4.320000E+03 7.822440E-08
/gps/hist/point 4.860000E+03 8.054666E-08
/gps/hist/point 5.400000E+03 8.235622E-08
/gps/hist/point 5.940000E+03 8.352866E-08
/gps/hist/point 6.750000E+03 8.435427E-08
/gps/hist/point 7.560000E+03 8.409541E-08
/gps/hist/point 8.640000E+03 8.315293E-08
/gps/hist/point 9.450000E+03 8.216144E-08
/gps/hist/point 1.080000E+04 8.006663E-08
/gps/hist/point 1.215000E+04 7.749806E-08
/gps/hist/point 1.350000E+04 7.466937E-08
/gps/hist/point 1.485000E+04 7.179544E-08
/gps/hist/point 1.701000E+04 6.718233E-08
/gps/hist/point 1.917000E+04 6.268859E-08
/gps/hist/point 2.160000E+04 5.798626E-08
/gps/hist/point 2.430000E+04 5.308789E-08
/gps/hist/point 2.700000E+04 4.862934E-08
/gps/hist/point 2.970000E+04 4.463575E-08
/gps/hist/point 3.240000E+04 4.103297E-08
/gps/hist/point 3.780000E+04 3.489178E-08
/gps/hist/point 4.320000E+04 2.991550E-08
/gps/hist/point 4.860000E+04 2.587164E-08
/gps/hist/point 5.400000E+04 2.255915E-08
/gps/hist/point 5.940000E+04 1.982345E-08
/gps/hist/point 6.750000E+04 1.655871E-08
/gps/hist/point 7.560000E+04 1.405674E-08
/gps/hist/point 8.640000E+04 1.163156E-08
/gps/hist/point 9.450000E+04 1.021269E-08
/gps/hist/point 1.080000E+05 8.227077E-09
/gps/hist/point 1.215000E+05 6.689205E-09
/gps/hist/point 1.350000E+05 5.483461E-09
/gps/hist/point 1.485000E+05 4.537968E-09
/gps/hist/point 1.701000E+05 3.429991E-09
/gps/hist/point 1.917000E+05 2.649494E-09
/gps/hist/point 2.160000E+05 2.025950E-09
/gps/hist/point 2.430000E+05 1.542522E-09
/gps/hist/point 2.700000E+05 1.201433E-09
/gps/hist/point 2.970000E+05 9.545918E-10
/gps/hist/point 3.240000E+05 7.708714E-10
/gps/hist/point 3.780000E+05 5.247968E-10
/gps/hist/point 4.320000E+05 3.742768E-10
/gps/hist/point 4.860000E+05 2.768246E-10
/gps/hist/point 5.400000E+05 2.108511E-10
/gps/hist/point 8.100000E+05 7.267635E-11
/gps/hist/point 1.080000E+06 3.373568E-11
/gps/hist/point 1.350000E+06 1.850901E-11
/gps/hist/point 1.620000E+06 1.130370E-11
/gps/hist/point 1.890000E+06 7.438663E-12
/gps/hist/point 2.160000E+06 5.171815E-12
/gps/hist/point 2.430000E+06 3.750810E-12
/gps/hist/point 2.700000E+06 2.812731E-12
/gps/hist/inter Lin
/gps/ang/type cos
/gps/ang/mintheta 0.000E+00 deg
/gps/ang/maxtheta 9.000E+01 deg
/gps/source/list
/control/alias NORM_FACTOR_SPECTRUM " 1.463051E+04 "
/control/alias NORM_FACTOR_ANGULAR " 2.500000E-01 "
Unfortunately, the exception occurs as follow:
G4DecayTable::SelectADecayChannel :: no possible DecayChannel neutron
*** G4Exception : DECAY003
issued by : G4Decay::DoIt
Can not determine decay channel for neutron
mass of dynamic particle: 0.930611 (GEV)
dacay table has 1 entries
0: BR 1, IsOK? 0, --> e- + anti_nu_e + proton
G4Track (058EE8A0) - track ID = 296, parent ID = 1
Particle type : neutron - creator process : ionInelastic, creator model : Binary Cascade
Kinetic energy : 0 eV - Momentum direction : (1,0,0)
Step length : 0 fm - total energy deposit : 0 eV
Pre-step point : (-17.813,23.3866,35.7244) - Physical volume : shield (G4_Al)
- defined by : not available
Post-step point : (-17.813,23.3866,35.7244) - Physical volume : shield (G4_Al) - defined by : not available
*** Note: Step information might not be properly updated.
Is there any solution to this problem besides
https://hypernews.slac.stanford.edu/HyperNews/geant4/get/hadronprocess/1588/1/1/1.html?&inline=1
Thank you,
Szymon
