Hi everyone, I’m a beginner of Geant4. I have build and installed Geant4_10_06 with Qt 5.14.1. When I was trying to execute exampleB1, some error arose. It show a dialogue box saying that exampleB1 can not find input point on Qt5OpenGl.dll. (MY system language is Chinese in the screenshot,sry, but it’s saying that.)
I think it is because .lib file which I used to generate the exampleB1.exe is not matching the .dll file. But after I delete all others Qt5OpenGl.dll in older version, it still gave this error.
Then I tried to run exampleB1.exe through qtcmd.
It was opend but couldn’t run init_vis.mac and give errors as
Geant4 version Name: geant4-10-06-patch-01 (14-February-2020)
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
Current available graphics systems are:
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
G4HepRep (HepRepXML)
G4HepRepFile (HepRepFile)
RayTracer (RayTracer)
VRML1FILE (VRML1FILE)
VRML2FILE (VRML2FILE)
gMocrenFile (gMocrenFile)
OpenGLImmediateWin32 (OGLIWin32, OGLIQt_FALLBACK)
OpenGLStoredWin32 (OGLSWin32, OGLSQt_FALLBACK)
Registered model factories:
generic
drawByAttribute
drawByCharge
drawByOriginVolume
drawByParticleID
drawByEncounteredVolume
Registered filter factories:
attributeFilter
chargeFilter
originVolumeFilter
particleFilter
encounteredVolumeFilter
ERROR: Can not open a macro file <init_vis.mac>. Set macro path with "/control/macroPath" if needed.
*** G4Exception : UIMAN0123
Command aborted (400)
Error code : 400
Dose anyone know where is the problem? And how can I fix this?
