Please fill out the following information to help in answering your question, and also see tips for posting code snippets . If you don’t provide this information it will take more time to help with your problem!
_Geant4 Version:_11.2
Operating System: Window 11
Hi all,
I have a problem with Geant4 output in ROOT format as show in attached image.
I hope can anyone help me to fix the problem.
Thank you in advance.
Best regards.
bmorgan
February 16, 2024, 5:13pm
2
Thanks @bmorgan .
Because the output file was generated from Geant4. So I hope anyone are expert in Geant4 and ROOT can help me fix the problem.
I think it is due to the scale factor that I set in the SetNumberOfParticles method of PrimaryGeneratorAction class.
PrimaryGeneratorAction::PrimaryGeneratorAction()
fPrimaryGeneratorActionMessenger = new PrimaryGeneratorActionMessenger(this);
particleGun = new G4ParticleGun();
particleGun->SetNumberOfParticles(500);
The last test with a factor of 250 was no error. The below output is the result of the test (BeamOn=1E9, Scale Factor=250). Here
If I scale it to 500 times, the error is like the post.Here is the result.
