Cannot visualization while running example B1
Hello there, I want to try running example B1 with visualization using OPENGL_WIN32 or QT (I use windows 10, VS2019, geant_10_06_p02 and QT 5.15.0), but still can’t visualize and this is the message what I get after running exampleB1.exe
error opengl.txt (8.4 KB)
hope can get best solution for this, thanks
do you have init_vis.mac and vis.mac in you directory where you execute the example?
Yes I have,… I already got the solution, the problem is I just forget to sets GEANT4_USE_OPENGL to ON
btw, thanks for the response
Hello Abuzanki, how did you solved this issue? I am having the same problem. Thank you!
