Dear All,
I am using the NeutronSource example. and I want to change the particle generator to GPS (It is gun type)
therefore I have replaced the PrimaryGeneratorAction.cc and PrimaryGeneratorAction.hh
I copied the new two files from the B1 example
I just copied and past without changing.
Now I have issues with the error: no matching constructor for initialization of ‘PrimaryGeneratorAction’
** PrimaryGeneratorAction* primary = new PrimaryGeneratorAction(fDetector);**
Do I need to change the ActionInitialization.cc and ActionInitialization.hh
That error’s because the primary generator action in example B1 has a constructor with no arguments:
whilst that in NeutronSource takes a pointer to the detector construction. Just update any instantiations of PrimaryGeneratorAction to use the no-argument form, e.g.
// wrong:
// PrimaryGeneratorAction* primary = new PrimaryGeneratorAction(fDetector);**
//should work
PrimaryGeneratorAction* primary = new PrimaryGeneratorAction();
Thanks a lot,
In the “ActionInitialization.cc” I replaced the
SetUserAction(primary);
To
But currently I have issues with the run manager, it is defined as gunparticle. Do I need to delete this definition??
“src/RunAction.cc:81:19: error: no member named ‘GetParticleGun’ in ‘PrimaryGeneratorAction’
= fPrimary->GetParticleGun()->GetParticleDefinition();
/Users/kafaal-khasawneh/JRTR/untitled folder/NeutronSource/src/RunAction.cc:82:33: error: no member named ‘GetParticleGun’ in ‘PrimaryGeneratorAction’
G4double energy = fPrimary->GetParticleGun()->GetParticleEnergy();”
