Hi~
I imported my model into GEANT4 using GDML file. My model consists about 1000 volumes except for world volume. Then I constructed a new volume by means of hard-coded programing(i.e., G4Sphere…). I want to set all the volumes in the gdml file(except world volume) as daughter volumes of this new volume. In other words, I want to change the mother volume of those cells from world volume to this new volume. Can anyone tell me how to achieve this?
I have tried
SetMotherLogical(G4LogicalVolume pMother) in G4VPhysicalVolume.hh file
and
AddDaughter(G4VPhysicalVolume p) in G4LogicalVolume.hh file,
but it doesn’t work.
Can anyone help me?
Thank you very much.
Thank you, John.
I found out that the SetSolid method was used to set the solid of a logical volume. However, what I want is to change the mother volume of several logical volumes. For example, there are 5 volumes in world volume. The mother volume of these 5 volumes is world volume. Then I construct a volume named X, which is also a daughter volume of world volume. What I want to do is to set those 5 volumes as daughter volumes of X volume. So what should I do?
Thank you sincerely,
jcren.
To change the mother of a ‘placement’ physical volume, you need to create a new placement volume in the new mother, and delete the old placement volume.
Thank you, John.
I tried one method several days ago and I’m wondering if my method was the same as yours. First I got the logical volumes of those 5 physical volumes, and placed them in the new mother volume(i.e., volume X). Then I tried to delete those 5 old volumes in the world volume using the method:
RemoveDaughter(const G4VPhysicalVolume* p)
However, I found out that I can only delete half of those 5 volumes(for instance, volume 1 and 3 were deleted but both volume 2 and 4 were not).
Did I use wrong method? Can you give me more suggestions?
jcren.
