I want to change certain parameters in my geometry, and change a scoring mesh accordingly.
The mesh was created with /score/mesh/cylinderSize 10 1 mm.
/score/open myMesh
/score/mesh/cylinderSize 10 1.5 mm
*** G4Exception : DigiHitsUtilsScoreVScoringMesh000
issued by : G4VScoringMesh::SetSize()
The size of scoring mesh is updated.
/score/close
besides this warning, the dose profile along the z-dimension of that cylinder (the one I change) does not follow the rescaling of that axis… is that expected?
Instead, the two curves are perfectly overlapping for the “rescaled” depth axis:
How can I make the size update known to my simulation?
edit: it becomes more obvious when changing the dimension of the part that should be analyzed: a cylinder of same dimensions/orientation as the scoring mesh:
// Modifications
// 17-Apr-2012 T.Aso SetSize() and SetNumberOfSegments() is not allowed
// to call twice in same geometrical mesh. Add warning
// message to notify.
forbidden calls to these two have error/warning messages: G4VScoringMesh::SetSize: “The size of scoring mesh is updated.” G4VScoringMesh::SetNumberOfSegments: “The size of scoring segments can not be changed.”
For version 11.0-beta, the warning for SetSize was removed (but not the comment in the header)…
update: just made a check with 11.0-beta, only the warning is indeed removed, but the mesh size effectively stays the same after issuing the commands as posted above.
the visualization (/score/drawProjection) however is updated properly. @taso
Hello.
Sorry for the ambiguous warning messages. Scoring mesh is not supposed to accept size changes so I will update the warning messages.
It is wired visualization accepts the change, and it should not. I will check it as well.
If you want to change the mesh size or mesh binning, please quit a program and restart it with new size or binning.
