CMake does not configure with Qt5 on macOS Ventura 13.2
Hi!
I try to configure CMake with Qt5 (installed via homebrew) on my macOS Ventura 13.2 and get the following error:
Checking C++ feature CXXSTDLIB_FILESYSTEM_NATIVE - Success
 CMake Error at /opt/homebrew/Cellar/qt@5/5.15.8_2/lib/cmake/Qt5Gui/Qt5GuiConfigExtras.cmake:9 (message):
   Failed to find "gl.h" in
   "/System/Library/Frameworks/OpenGL.framework/Headers;/System/Library/Frameworks/AGL.framework/Headers".
   /opt/homebrew/Cellar/qt@5/5.15.8_2/lib/cmake/Qt5Gui/Qt5GuiConfig.cmake:227 (include)
   /opt/homebrew/Cellar/qt@5/5.15.8_2/lib/cmake/Qt5/Qt5Config.cmake:28 (find_package)
   cmake/Modules/G4InterfaceOptions.cmake:142 (find_package)
   cmake/Modules/G4CMakeMain.cmake:64 (include)
   CMakeLists.txt:50 (include)
In fact, the above-mentioned headers are not there. After some googling I managed to modify the Qt5GuiConfigExtras.cmake file to point it to the direction where I could locate those header files and it seems to find all Qt related packages but it ends up in a new error:
CMake Error at /opt/homebrew/Cellar/cmake/3.25.2/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
   Could NOT find OpenGL (missing: OPENGL_INCLUDE_DIR)
   /opt/homebrew/Cellar/cmake/3.25.2/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:600
 (_FPHSA_FAILURE_MESSAGE)
   /opt/homebrew/Cellar/cmake/3.25.2/share/cmake/Modules/FindOpenGL.cmake:443 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
   cmake/Modules/G4InterfaceOptions.cmake:199 (find_package)
Hereby, I run the following command in my build directory:
ccmake -DCMAKE_PREFIX_PATH=/opt/homebrew/Cellar/qt@5/5.15.8_2/lib/cmake ..
Sidenote: by disabling Qt, I successfully compile Geant4 11.1.0 and run B1. However, in the vis.mac file I need to uncomment the line /vis/open/ VRML2FILE as it otherwise complains about /vis/open OGL 600x600-0+0 since it does not find OpenGL.
I understand that it is more OS-related issue (paths to OpenGL?) rather than G4, but maybe someone had similar troubles…
Any help is much appreciated! Thanks in advance
Jurij
Hi Jurij
I find
cmake ... -DCMAKE_PREFIX_PATH="$(brew --prefix qt@5);..." ...
does the trick.
I have in my .profile
export PATH="/opt/homebrew/opt/qt@5/bin:$PATH"
following some printed out instructions when I installed it with brew. John’s answer is the nice dynamic solution.
Laurie
Thank you both for a very quick reply!
Unfortunately, I still get the same errors trying both of your solutions. Followed even hints from here: Installation on macOS (M series)
but without any success…
One thing - I have disabled using system Expat since they weren’t found either - does it has any impact?
BR, Jurij
Using builtin expat shouldn’t make a difference, but the fact that system Expat and the OpenGL headers points, I think, to a system issue.
Do you have the command line developers tools installed and/or Xcode? Also, was this a completely fresh, from scratch build of Geant4, i.e. not reusing an existing build directory that might have old files in?
yes, I have both Xcode and CLT (ver 14.2). I even installed Apple’s OpenGL Metal since I read somewhere that Apple started providing their own OpenGL. Reinstalled Qt5 as well. Restarted my machine x times.
And yes, a completely fresh Geant4 installation. Intuitively, I also guess that it’s something weird with my OS. Will probably wait until next OS update and see if the error disappears. Yet, I can run Geant4 so it is not fully hopeless))
I tried: cmake -DCMAKE_PREFIX_PATH=/opt/homebrew/Cellar/qt@5/5.15.2_1/lib/cmake
and it fine with me
