CMakeList.txt - extra include directories
Sorry for a basic question.
Geant4 Version: geant4-v11.2.2
_Operating System:_Mac OS
_Compiler/Version:_Apple clang version 15.0.0 (clang-1500.3.9.4)
_CMake Version:_cmake version 3.21.4
I am trying to build a new application based on the G01 example.
I have copied the directory and have made changes to the CMakeList.txt for the change of name.
When I run cmake it runs okay
cmake -DCMAKE_PREFIX_PATH=$G4INSTALL .
– Configuring done
– Generating done
– Build files have been written to: /Users/keithsloan/geant4-v11.2.2-Examples/KS_LGC01/build
But on subsequent make i get
keithsloan@Keiths-iMac-2 build % make
[ 25%] Building CXX object CMakeFiles/load_gdml_color.dir/load_gdml_color.cc.o
/Users/keithsloan/geant4-v11.2.2-Examples/KS_LGC01/load_gdml_color.cc:71:10: fatal error: ‘GeometryMoments.hh’ file not found
#include “GeometryMoments.hh”
1 error generated.
make[2]: *** [CMakeFiles/load_gdml_color.dir/load_gdml_color.cc.o] Error 1
make[1]: *** [CMakeFiles/load_gdml_color.dir/all] Error 2
So it looks like the CMakeList.txt needs extra info on where to find various include directories
Hi Keith,
In my experience you probably only need to change the final name at the bottom of the cmakelists file. You would probably have to share the rest of the changes you made but geant4 invludes are inherited from the main cmake file under the directory you installed the toolkit. Ie installDir/lib/cmake/Geant4
So you wouldnt have to add anything else.
Ps thanks for the gdml workbench.
The files it is failing to find are in the include of the directory I have created.
CMakeLists.txt has
Locate sources and headers for this project
include_directories(${PROJECT_SOURCE_DIR}/include
${Geant4_INCLUDE_DIR})
file(GLOB sources ${PROJECT_SOURCE_DIR}/src/.cc)
file(GLOB headers ${PROJECT_SOURCE_DIR}/include/
.hh)
So I don;t see why it is not picking up from include_directories(${PROJECT_SOURCE_DIR}/include
My understanding is that CMake does not export stuff to Env, so how do I debug?
Okay.
I create build under KS_LGC01
cd to build
Then do cmake -DGeant4_DIR=$G4DIR … -DCMAKE_PREFIX_PATH=$G4INSTALL .
and then make from there but the includes are in KS_LGC01/include
but not in KS_LGC01/build/include
Header files can just be added to the include dir.
If you are trying to copy another file or directory into the build directory for example a macro dir you need to have it as following.
foreach(_file ${someDir}
    configure_file(
    ${_file}
    ${PROJECT_BINARY_DIR}/${_file}
    COPYONLY
endforeach()
Something like this. You can look under various examples how macros are copied over.
If you move the bin dir after using cmake generate then it wont work.
