Hi All,
I have a question about colors… How can I change the color of a box?
I was able to change the color of the contouring lines, but not the inner region.
Hi All,
Hi Valeria
Not quite sure what you mean - contouring lines? inner region?
There are several ways to set the colour:
Set the vis attributes (G4VisAttributes) in the logical volume;
At run time, use /vis/geometry/set/colour.
Also, you can change from wireframe to surface drawing with /vis/viewer/set/style.
If you are using the Qt GUI, you can change the colour of individual volumes in the “scene tree” and there is some “right click” functionality about styles.
Hi @allison
Thanks!
Yes, the question was about how to change colours of individual volumes, related to the inner regions.
In the end I solved exactly in the same you have suggested.
Thanks anyway!
Valeria
