Command not found when using /process/had/rdm in gammaknife example
Geant4 Version: 11.3.2
Operating System: Pop!_OS 22.04 LTS(Ubuntu based)
Compiler/Version: g++ 11.4.0
CMake Version: 3.22.1
I was trying to use the gammaknife example in the geant4 source, and upon the execution of the macro file, error occured at this line:
/process/had/rdm/thresholdForVeryLongDecayTime 1.0e+60 year
The error is the following:
***** COMMAND NOT FOUND </process/had/rdm/thresholdForVeryLongDecayTime 1.0e+60 year> *****
*** G4Exception : UIMAN0123
Command aborted (100)
Error code : 100
And the execution stops there.
Does anyone know how to fix this error?
That error appears when Radioactive Decay is not activated, e.g. if you use the physics list FTFP_BERT.
If, instead, you use a physics list with particleHP activated - which automatically includes Radioactive Decay - then everything should work fine.
For instance:
export PHYSLIST=FTFP_BERT_HP
(or QGSP_BIC_HP, Shielding, etc.).
Thanks! It solved my problem
