Compilation Error in Geant4 B1 Example
Geant4 Version: 11.2.1
Operating System: Ubuntu 22.04.4 LTS
Conda Version: 23.9.0
CMake Version: 3.26.3
I’m encountering a compilation error while trying to build the Geant4 B1 example. Here’s the error message I’m receiving:
(G4-Ayoub) mlahdour@ThinkCentre:~/Bureau/Ayoub/software/geant4-v11.2.1-install/share/Geant4/examples/basic/B1/build$ make
[ 12%] Building CXX object CMakeFiles/exampleB1.dir/exampleB1.cc.o
/home/mlahdour/Bureau/Ayoub/software/geant4-v11.2.1-install/share/Geant4/examples/basic/B1/exampleB1.cc: In function ‘int main(int, char**)’:
/home/mlahdour/Bureau/Ayoub/software/geant4-v11.2.1-install/share/Geant4/examples/basic/B1/exampleB1.cc:80:50: error: no matching function for call to ‘G4VisExecutive::G4VisExecutive(int&, char**&)’
   80 |   auto visManager = new G4VisExecutive(argc, argv);
In file included from /usr/local/include/Geant4/G4VisExecutive.hh:132,
                 from /home/mlahdour/Bureau/Ayoub/software/geant4-v11.2.1-install/share/Geant4/examples/basic/B1/exampleB1.cc:38:
/usr/local/include/Geant4/G4VisExecutive.icc:126:1: note: candidate: ‘G4VisExecutive::G4VisExecutive(const G4String&)’
  126 | G4VisExecutive::G4VisExecutive (const G4String& verbosityString):
/usr/local/include/Geant4/G4VisExecutive.icc:126:1: note:   candidate expects 1 argument, 2 provided
/home/mlahdour/Bureau/Ayoub/software/geant4-v11.2.1-install/share/Geant4/examples/basic/B1/exampleB1.cc:111:10: error: type ‘<type error>’ argument given to ‘delete’, expected pointer
  111 |   delete visManager;
make[2]: * [CMakeFiles/exampleB1.dir/build.make:76 : CMakeFiles/exampleB1.dir/exampleB1.cc.o] Erreur 1
make[1]: * [CMakeFiles/Makefile2:84 : CMakeFiles/exampleB1.dir/all] Erreur 2
make: * [Makefile:136 : all] Erreur 2
  • I’ve created a new Conda environment specifically for this version to avoid conflicts with the older version 11.1.2.
Thank you,
Hi
First, when supplying code or output, please use triple-back-accent (``` on a separate line), then the code/output, terminated by another ```. Or an attachment. Not an screenshot.
Mmm. Seems you are using an old version of G4VisExecutive.icc. Do you have your own copy? Should not be needed. In your main program file:
#include "G4VisExecutive.hh"
should be enough. It includes G4VisExecutive.icc from the geant4 source tree.
At least, that’s how it looks. Let us know if this is a misdiagnosis.
Thank you for your remark, John. Yes, indeed, "G4VisExecutive.hh" is included in the main file.
/// \file exampleB2b.cc
/// \brief Main program of the B2b example
#include "DetectorConstruction.hh"
#include "ActionInitialization.hh"
#include "G4RunManagerFactory.hh"
#include "G4SteppingVerbose.hh"
#include "G4UImanager.hh"
#include "FTFP_BERT.hh"
#include "G4StepLimiterPhysics.hh"
#include "Randomize.hh"
#include "G4UIExecutive.hh"
int main(int argc,char** argv)
Additionally, I’ve tested with another extended example (Hadr04). Here’s the output:
(G4-Ayoub) mlahdour@ThinkCentre:~/Bureau/Ayoub/software/geant4-v11.2.1-install/share/Geant4/examples/extended/hadronic/Hadr04/build$ ./Hadr04
Available UI session types: [ tcsh, csh ]
 Geant4 version Name: geant4-11-01-patch-02 [MT]   (15-June-2023)
  << in Multi-threaded mode >>
                                 : IEEE-TNS 53 (2006), 270-278
                                 : NIM A 835 (2016), 186-225
                             WWW : http://geant4.org/
  ASCIITree (ATree)
  DAWNFILE (DAWNFILE)
  G4HepRepFile (HepRepFile)
  RayTracer (RayTracer)
  VRML2FILE (VRML2FILE)
  gMocrenFile (gMocrenFile)
Registered model factories:
  generic
  drawByAttribute
  drawByCharge
  drawByOriginVolume
  drawByParticleID
  drawByEncounteredVolume
Registered models:
  None
Registered filter factories:
  attributeFilter
  chargeFilter
  originVolumeFilter
  particleFilter
  encounteredVolumeFilter
Registered filters:
  None
PreInit>
when I run cmake …, it indicates that Geant4 version 11.1.2 is found, even though I’m working with version 11.2.1.
(base) mlahdour@ThinkCentre:~/Bureau/Ayoub/software/geant4-v11.2.1-install/share/Geant4/examples/basic/B3/B3a/build$ cmake ..
-- The C compiler identification is GNU 11.4.0
-- The CXX compiler identification is GNU 11.4.0
-- Check for working C compiler: /usr/bin/cc - skipped
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Found EXPAT: /usr/lib/x86_64-linux-gnu/libexpat.so (found suitable version "2.4.7", minimum required is "2.4.7")
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- Found Geant4: /usr/local/lib/cmake/Geant4/Geant4Config.cmake (found version "11.1.2")
-- Configuring done (0.3s)
-- Generating done (0.0s)
-- Build files have been written to: /home/mlahdour/Bureau/Ayoub/software/geant4-v11.2.1-install/share/Geant4/examples/basic/B3/B3a/build
Hi Ayoub
That certainly explains it. Of course, one must compile and link with the correct Geant4 code and libraries. Do you know how to do this? Can you correct the above problem yourself? (Have a look at the Installation Guide.) Let us know if it fixes things for you.
Hi John,
Thanks for your reply and clarification! You’re absolutely right, I needed to link the libraries.
I was able to fix it by running . geant4make.sh within the following path :
/path/to/geant4-v11.0.0-install/geant4.sh
Ayoub
Hi Ayoub
That’s great. Thanks for letting us know.
