Compiling geant4 simulation on lxplus
Dear experts, I am trying to run one geant4 simulation on Lxplus but the CMake doesn’t work, it says me //
Failed to find XercesC (missing: XercesC_LIBRARY XercesC_INCLUDE_DIR
XercesC_VERSION) (Required is at least version “3.2.3”)
But I do it (XercesC_INCLUDE_DIR=/cvmfs/sft.cern.ch/lcg/releases/XercesC/3.2.3-714f6/x86_64-centos7-gcc9-opt/include/xercesc) … or maybe it is bad done …
I am going to attach the screenshot … I am doing something bad …
If you know something about this, please let me know.
Thanks in advance.
What LCG packages/views did you setup (via setup.sh scripts or similar) before running cmake? These should generally setup all dependencies, but one might have got lost.
Thanks a lot for answering, I think I haven’t called any of them. This is my setup
Thanks for the detail! If you only need this setup for Geant4 or a common software stack, it might be better to use one of the LCG views, which do setup everything, for example:
$ source /cvmfs/sft.cern.ch/lcg/views/LCG_100/x86_64-centos7-gcc10-dbg/setup.sh
It should then be possible to run cmake for your application without the need to pass any Geant4/etc variables. Depending on the exact platform, compiler and Geant4 version you require, you can adjust the above LCG_XXX/<arch>-<platform>-<compiler>-<spec>/ to meet these. A full list is available on the LCG Info site (CERN login required).
Dear Morgan, thanks for your help.
I solved this problem but I have a new one :frowning: after running the setup.sh and building the executable when I am going to run it there is a message
./Gem: /lib64/libstdc++.so.6: version GLIBCXX_3.4.20' not found (required by ./Gem) ./Gem: /lib64/libstdc++.so.6: version CXXABI_1.3.9’ not found (required by ./Gem)
I have attached the setup.sh file.
Thanks! :slight_smile:
You’ll also need to source the same setup scripts before running the application. The application is linked against libraries (here, the GNU C++ library) that are in non-standard locations. The scripts setup the needed environment to do this pointing, and it needs to be the same both when building and running the appilication.
Thanks!!! now it is running! :+1:
