Confine particles
Currently, I am working on a project, involving the generation of particles in four spheres, all sharing the same center located at coordinates (0,0,0) but with different radii. My goal is to confine these particles within a precise volume defined by the spheres, for example : 1000000 particles between Rmin = 0.001 mm and Rmax = 0,002 mm
I have explored a few approaches to achieve this goal, including using the /gps/pos/confine command in a .mac file. However, I have not been able to obtain the desired results with this method.
I also tried
posx = (2*G4UniformRand()-1)Rmax;
posy = (2
posz = (2
G4UniformRand()-1)*Rmax;
r = std::sqrt(pow(posx,2)+pow(posy,2)+pow(posz,2));
But, it always take random position, outside of the desired range.
Capture d’écran 2023-10-16 à 11.27.57
You need to use spherical coordinates.
What you need to do is randomly generate 2 angles, Then generate a random radius. You can constrict this radius to be within whichever sphere you want.
You will also have to scale your radius by r = sqrt(random()), or else you will have more points closer to the center of your sphere
examples/extended/eventgenerator/particleGun/src
PrimaryGeneratorAction4.cc : lines ~50-55 and ~69-79
You may prefer to use GeneralParticleGun. See Geant4 doc.
Thank you, i will try that
Thank you so much, i’ll try that too
