/control/execute COMMAND NOT FOUND
Dear experts,
I’m new to Geant4, and I’m using some user-defined code to make G4Solid from a macro file, but when I try to run the simulation I got errors like:
***** COMMAND NOT FOUND <{parent}/Dimension FeedThroFromEPOut = 10.0*mm> *****
***** COMMAND NOT FOUND </control/execute {geometry_macros}/CylindricalDriftChamber.macro> *****
***** COMMAND NOT FOUND </control/execute {SIMG4ROOT}/geometry_macros/SingleCDCCosmicRayTest.macro> *****
are these errors indicate that I had typos in my path? Or it’s just that the environment was not able to be gotten…?
Any suggestions? I still don’t understand why the basic commands are not found
It seems the errors are due to undefined environment variables like SIMG4ROOT or geometry_macros. Could you confirm if these are set? Sharing the macro file might also help…
