I am shooting neutron to water and gadolinium mixture in Had06/Had04 example. I am trying to count the number of capture on water and number of capture on Gadolinium . I did the following modifcation in trackingaction
if (track->GetParentID() == 0 && track->GetDefinition() == G4Neutron::Neutron()) {
// Primary neutron
if (track->GetTrackStatus() == fStopAndKill && track->GetStep()->GetPostStepPoint()->GetProcessDefinedStep()->GetProcessName() == “nCapture”) {
// Primary neutron is captured
const G4TouchableHandle& touchable = track->GetStep()->GetPreStepPoint()->GetTouchableHandle();
const G4Material* material = touchable->GetVolume()->GetLogicalVolume()->GetMaterial();
1- your if conditions to get material names seem ok, although somewhat redundant.
but what are these names : Gadolinium, Hydrogen ? from where do they come ?
To get the target nucleus of each individual capture, see example Hadr03: SteppingAction.cc, around lines 88-92
2- you count capture cases with “gadoliniumCapureCount” , “hydrogenCaptureCount” .
where these counters are defined and initialized ?
I want to count how many neutron captured on hydrogen and gadolinium separately. In Had03 as you, give Gd157 . All are captured on Gd157 non of on Hydrogen . This is giving me suspicion.
The abundance and capture cross section of Gd157 is 15.7% and 254000 b respectively. For Gd155 they are 14.8% and 60900 b. The capture cross section for H1 is 0.33 b. So it is not surprising that all the captures occur on Gd. (From your code, I do not see that the counter distinguishes Gd157 from Gd155 capture.) If you fired enough primary neutrons, eventually you would get a H1 capture.
