Crash with low energy particles by gps
Geant4 Version:11.3.2
Operating System:windows11
Compiler/Version:Microsoft Visual Studio Commnity 2022
*CMake Version:*3.24.202208181-MSVC_2
My simulation crashes when I use the following command. If I change the unit from keV to MeV, the simulation runs successfully.Some times My simulation crashes even if I set MeV.
/gps/pos/type Volume
/gps/pos/shape Cylinder
/gps/pos/centre 0. 0. 0.015 mm
/gps/pos/radius 5 cm
/gps/pos/halfz 0.015 mm
/gps/particle e-
/gps/ang/type iso
/gps/energy 18.6 keV
/run/beamOn 1
Not enough information. What physics list are you using? What does your geometry look like (_describe_ it, don’t just post code and expect us to figure it out). What exactly goes wrong? What error messages do you get? Do you get a traceback? Did you build Geant4 with debugging information in order to get a usable traceback? Have you tried running in the debugger yourself?
Sorry for My lacking infomation.I wana simulate the model like the picture below and ScT2 is source of e-. I’m using FTFP_BRERT and G4Radio active Decay Phisics. my qt window crashes with no error.
I tried to figure out the cause of this problem and I noticed a condition of crash. If I set electric field to gap,It crashes.Even if voltage is 0. This is the code to set electric field to the gap.Are there obvious mistakes in my code?
auto eField = new G4UniformElectricField(G4ThreeVector(0.,0.,voltage/gap_len));
auto fieldMgr = new G4FieldManager();
fieldMgr->SetDetectorField(eField);
logic_gap->SetFieldManager(fieldMgr, true);
Is this code part of the ConstructSDandField() function in your DetectorConstruction class? If so, is logic_gap a data member of that class, and is it properly set before you use it?
