Hey, I am relatively new to Geant4, and I’m sure this is a pretty basic task but I had a few questions about it anyway. So as far as I know, a uniform magnetic field can be created by using the G4UniformMagneticField class with a G4ThreeVector that contains the uniform 3D values of the field. One can then create a field manager, assign a chord finder to it, and then put the manager inside any logical volume in a setup.
I have a simple geometric setup with a rectangular world filled with air, and a cylindrical detector filled with LaBr3. I am trying to add both uniform electric and magnetic fields to it, but I only know how to use the G4UniformElectricField and the G4UniformMagneticField classes independently - by which I mean that I can create these fields and put them in a field manager and put the field manager in a logical volume, but I do not know how to put both fields inside the same manager/volume.
I am aware that there is a class called G4ElectromagneticField but as far as I understand, this class needs some sort of 3-D point wise data for it? As in, it is meant for non uniform fields? How does one use this for my task?
And lastly, do I need to do anything other than what I have mentioned so far for creating and assigning a field to a logical volume? I am not working with sensitive detectors - I am using the concept of scoring volumes instead. I am creating and assigning fields inside the usual DetectorConstruction class.
Please let me know if I need to provide more details for my inquiries.
Thanks in advance!
