Creating Electric field in specific volume using fieldBuilder
_Geant4 Version:_11.3
_Operating System:_Windows 11
_Compiler/Version:_Microsoft (R) C/C++ Optimizing Compiler Version 19.42.34433 for x86
_CMake Version:_3.31.0
As the title suggests, I am trying to create an electric field inside a specific volume within the world volume.
As you can see from the code below, I have added code that creates a magnetic field. Adding a magnetic field instead of an electric field gives exactly what I expect (the field inside the field volume), but adding an electric field instead causes g4 gui to crash.
Here is my detector construction. Please let me know if you need to see more:
#include "G4UniformElectricField.hh"
#include "G4UniformMagField.hh"
#include "G4SystemOfUnits.hh"
#include "G4FieldBuilder.hh"
#include "G4Material.hh"
VolumeConstruction::VolumeConstruction()
  // create field builder
  // this will create commands for field parameters
  G4FieldBuilder* fieldBuilder = G4FieldBuilder::Instance();
  // fieldBuilder->SetVerboseLevel(2);
  auto localFieldParameters = fieldBuilder->CreateFieldParameters("logicalFieldVolume");
  // set default min step 0.25 mm
  localFieldParameters->SetMinimumStep(0.25 * mm);
VolumeConstruction::~VolumeConstruction()
G4VPhysicalVolume* VolumeConstruction::Construct()
	//-------Build world (mother volume)------------
    G4Material* worldMat = nist->FindOrBuildMaterial("G4_Galactic");
	//Creating solid volume
	G4double worldSizeX = 400*mm;
	G4double worldSizeY = 400*mm;
	G4double worldSizeZ = 600*mm;
    G4Box* solidWorld = new G4Box("solidWorld", worldSizeX/2, worldSizeY/2, worldSizeZ/2);
	//Creating logical volume
logical volume
    G4LogicalVolume* logicWorld = new G4LogicalVolume(solidWorld, worldMat, "logicWorld");
    // Creating physical volume for interactions,
    G4VPhysicalVolume* physWorld = new G4PVPlacement(0, G4ThreeVector(0., 0., 0.), logicWorld,
	"physWorld", 0, false, 0, true);
	//-------Defining Electric Field Volume------
	// Creating solid volume of field region
	fieldRegionSizeX = 49.5 * mm;
	fieldRegionSizeY = 49.5 * mm;
	fieldRegionSizeZ = 100 * mm;
	G4Box *eFieldVolume = new G4Box("eFieldVolume", fieldRegionSizeX/2, fieldRegionSizeY/2, fieldRegionSizeZ/2);
	// Creating logical volume of field region
	logicalFieldVolume = new G4LogicalVolume(eFieldVolume, worldMat, "logicalFieldVolume");
	// Creating physical volume of field region
	fieldZ0 = -10*cm;
	G4VPhysicalVolume *physFieldVolume = new G4PVPlacement(0, G4ThreeVector(0., 0., fieldZ0), logicalFieldVolume,
	"physFieldVolume", logicWorld, false, 0, true);
    return physWorld;
void VolumeConstruction::SetLocalFieldValue(G4ThreeVector value)
  fLocalFieldVector = value;
  G4UniformElectricField* eField = nullptr;
  //G4UniformMagField* magField = nullptr;
  if (fLocalFieldVector != G4ThreeVector(0.,0.,0.)) {
    eField = new G4UniformElectricField(fLocalFieldVector);
	//magField = new G4UniformMagField(fLocalFieldVector);
  // Set field to the field builder
  auto fieldBuilder = G4FieldBuilder::Instance();
  fieldBuilder->SetLocalField(eField, logicalFieldVolume);
  //fieldBuilder->SetLocalField(magField, logicalFieldVolume);
void VolumeConstruction::ConstructSDandField()
  // Create detector fields
  SetLocalFieldValue(fLocalFieldVector);
  // Construct all Geant4 field objects
  fieldBuilder->SetFieldType(kElectroMagnetic);
  fieldBuilder->ConstructFieldSetup();
Before the gui crashes, the below exception is shown:
G4Exception : GeomFieldParameters0001
  issued by : G4FieldSetup::CreateEquation:
Incompatible field and equation.
The field type must be set explicitly for other than magnetic field.
Fatal Error in Argument *** core dump ***
  Track information is not available at this moment
  Step information is not available at this moment
I tried to address this problem by adding the line:
but this doesn’t seem to have fixed the problem.
I reply here to add that I am encountering the exact same issue, and as such would also like to know if you have found a fix @Dillon_Anderson
Best regards.
To add context, the issue is that there is no way (that I am aware of) to define the type only for the local field, as such, only the global field is correctly identified :
G4FieldBuilder::ConstructField
G4FieldBuilder::ConstructGlobalField
Global field created with stepper ClassicalRK4
Magnetic field parameters:
  field type = ElectroMagnetic
  equation type = EqElectroMagnetic
  stepper type = ClassicalRK4
  minStep = 0.01 mm
  constDistance = 0 mm
  deltaChord = 0.25 mm
  deltaOneStep = 0.01 mm
  deltaIntersection = 0.001 mm
  epsMin = 5e-05
  epsMax=  0.001
G4FieldBuilder::ConstructLocalFields()
Construct local field in volume: logicDetector
Local (in logicDetector) field created with stepper DormandPrince745
  volume name = logicDetector
  field type = Magnetic
  equation type = EqMagnetic
  stepper type = DormandPrince745
  minStep = 0.01 mm
  epsMin = 5e-05
  epsMax=  0.001
G4FieldBuilder::UpdateFieldSetups
Global field updated with stepper ClassicalRK4
  minStep = 0.01 mm
  epsMin = 5e-05
  epsMax=  0.001
The code is presented below :
    //Adding electric field to the detector
    G4FieldBuilder *fieldBuilder = G4FieldBuilder::Instance();
    //Defining the field value
    G4UniformElectricField *eField = new G4UniformElectricField(G4ThreeVector(0.0, 20*kilovolt/cm, 0.0));
    fieldBuilder->SetLocalField(eField, logicDetector);
If anyone needs the solution, following this post solution, as follows :
    //Defining local field parameters
    auto localFieldParameters = fieldBuilder->CreateFieldParameters("logicDetector");
    localFieldParameters->SetFieldType(kElectroMagnetic);
    localFieldParameters->SetEquationType(kEqElectroMagnetic);
    //Using field builder to set up the field
    fieldBuilder->SetLocalField(elField, logicDetector);
