Custom user-defined ion with decay table never decays during tracking
Summary
My goal is to create ions with user-defined static properties and a user-defined decay scheme.
The new ion should transport and interact with matter like any other ion defined in Geant4.
Problem:
The ion never decays during tracking, even though its lifetime is extremely short.
Geant4 version: 11.3.2
Description: Ubuntu 24.04.2 LTS
Linux LT-25-0031 6.6.87.2-microsoft-standard-WSL2 #1 SMP PREEMPT_DYNAMIC Thu Jun 5 18:30:46 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
g++ (Ubuntu 13.3.0-6ubuntu2~24.04.1) 13.3.0
cmake version 3.28.3
Greetings to the community,
I would like to define ions with the following parameters completely defined by the user.
G4Ions(
const G4String& aName, G4double mass,
G4double width, G4double charge,
G4int iSpin, G4int iParity,
G4int iConjugation, G4int iIsospin,
G4int iIsospin3, G4int gParity,
const G4String& pType, G4int lepton,
G4int baryon, G4int encoding,
G4bool stable, G4double lifetime,
G4DecayTable *decaytable, G4bool shortlived,
const G4String& subType =“”,
G4int anti_encoding =0,
G4double excitation = 0.0
including a user-defined decay scheme.
These ions should behave exactly like any other ion implemented in Geant4 (transportation, interaction with matter, etc.).
Below are the steps I followed.
1) I defined a custom ion type inheriting from G4Ions
#ifndef DRAGONION_HH
#define DRAGONION_HH
#include “G4Ions.hh”
namespace DRAGON
class DRAGONIon : public G4Ions {
public:
DRAGONIon(const G4String& name,
G4double mass,
G4double width,
G4double charge,
G4int iSpin,
G4int iParity,
G4int iConjugation,
G4int iIsospin,
G4int iIsospin3,
G4int gParity,
const G4String& type,
G4int lepton,
G4int baryon,
G4int encoding,
G4bool stable,
G4double lifetime,
G4DecayTable* decaytable,
G4bool shortlived,
G4int Z,
G4int A);
virtual ~DRAGONIon() = default;
#endif
#include “DRAGONIon.hh”
namespace DRAGON
DRAGONIon::DRAGONIon(const G4String& name,
G4double mass,
G4double width,
G4double charge,
G4int iSpin,
G4int iParity,
G4int iConjugation,
G4int iIsospin,
G4int iIsospin3,
G4int gParity,
G4int lepton,
G4int baryon,
G4int encoding,
G4bool stable,
G4double lifetime,
G4bool shortlived,
G4int Z,
G4int A)
: G4Ions(name, mass, width, charge, iSpin, iParity, iConjugation,
iIsospin, iIsospin3, gParity, type, lepton, baryon,
encoding, stable, lifetime, decaytable, shortlived)
SetAtomicNumber(Z);
SetAtomicMass(A);
2) Inside a method called ureact() (which is called from ConstructParticle()), I create the ions involved
//C
//C → Define Ne19++++ ion
//C
ipart = 61;
aamass = 19.*0.93149432;
ubuf[0] = 4;
tlif = 1000.;
if(!G4ParticleTable::GetParticleTable()->FindParticle("Ne19++++ "))
DRAGONIon* ion = new DRAGONIon(
"Ne19++++ ",
aamass*GeV,
0.0,
ubuf[0]eplus,
1, +1, 0, 0, 0, 0,
“nucleus”,
0, +19, ipart,
false,
tlif
s,
nullptr,
false,
10,
19
3) I define and assign the decay scheme with something like this
brat[0] = 95.;
mode[0] = 84;
brat[1] = 5.;
mode[1] = 83;
G4DecayTable* decayTable2 = new G4DecayTable();
for (int i = 0; i < 10; i++)
if(mode[i])
G4VDecayChannel* decayChannel = new G4PhaseSpaceDecayChannel(
G4ParticleTable::GetParticleTable()->FindParticle(82)->GetParticleName(),
brat[i]/100.,
1,
G4ParticleTable::GetParticleTable()->FindParticle(mode[i])->GetParticleName()
decayTable2->Insert(decayChannel);
DRAGONIon* part1 =
dynamic_cast<DRAGONIon*>(G4ParticleTable::GetParticleTable()->FindParticle(82));
part1->SetDecayTable(decayTable2);
decayTable2->DumpInfo();
4) Immediately after that, I print the ion information and obtain
===== Ion Properties =====
Type: nucleus
SubType:
PDG Encoding: 89
Mass: 14.9061 GeV
Charge: 6 e
Spin: 0
Magnetic Moment: 0
Parity: 1
Isospin: 0
Isospin3: 0
Stable: No
Lifetime: 4.7e-15 s
Atomic Number (Z): 8
Atomic Mass (A): 16
Excitation Energy: 0 eV
G4DecayTable: 16O_3
0: BR: 0.9997 [Phase Space] : 16O_
1: BR: 0.00027 [Phase Space] : 16O_1
2: BR: 8e-05 [Phase Space] : 16O_2
However, during tracking I would expect these ions to decay almost immediately, given their extremely short lifetime. Nevertheless, they never decay.
5) This is the physics list implementation
DRAGONPhysicsList::~DRAGONPhysicsList()
delete fMessenger;
delete fDecPhysicsList;
delete fEmPhysicsList;
delete fIonPhysicsList;
delete fStepLimiterPhysics;
delete fHadElastPhysics;
delete fHadPhysicsFTFP_BERT;
void DRAGONPhysicsList::ConstructParticle()
// Particle table initialization
fEmPhysicsList->ConstructParticle();
fDecPhysicsList->ConstructParticle();
fIonPhysicsList->ConstructParticle();
fHadElastPhysics->ConstructParticle();
fHadPhysicsFTFP_BERT->ConstructParticle();
// Define radioactive ion reactions
ureact();
void DRAGONPhysicsList::ConstructProcess()
G4cout << “From Physics ConstructProcess()” << G4endl;
AddTransportation();
fEmPhysicsList->ConstructProcess();
fDecPhysicsList->ConstructProcess();
fIonPhysicsList->ConstructProcess();
fStepLimiterPhysics->ConstructProcess();
fHadElastPhysics->ConstructProcess();
fHadPhysicsFTFP_BERT->ConstructProcess();
AddIonGasModels();
Any help or suggestions would be greatly appreciated.
Best regards.
Dear @norach1991 ,
What is the purpose of these DRAGONIONS ? There are ways to use a “regular” Ne-19 ion and simply hijack it’s decay table. You can do so by “overriding” the file to be used as the decay table. Whether a short [too] short lived particle is transported or decayed immediately is another question.
/process/had/rdm/setRadioactiveDecayFile Z A FILE
you can copy the file from the regular dataset, just grab z7.a19, modify it and point to it.
/Pico
Thanks for your reply. The issue is that I need full freedom to define the values of all these parameters that define the particle and are given to the G4ParticleDefinition class’ constructor. Defining an ion via G4ParticleDefinition *na_ion = ionTable->GetIon(Z, A, 0); is not a good option because it does not offer me the level of freedom I need, so I need to define my own ions.
I call this method from ConstructParticle():
void DRAGONPhysicsList::CreateExoticIon() {
  if (!G4ParticleTable::GetParticleTable()->FindParticle("ExoticIon")) {
    G4String name = "ExoticIon";
    G4double mass = 50.0*GeV;
    G4double width = 0.0*MeV;
    G4double charge = 20.0*eplus;
    G4int spin = 0;
    G4int parity = +1;
    G4int CConjugation = 0;
    G4int isospin = 0;
    G4int isospin3 = 0;
    G4int GParity = 0;
    G4String type = "nucleus";
    G4int leptonNumber = 0;
    G4int baryonNumber = 50;
    G4int encoding = 12345;
    G4ParticleDefinition* ion = new G4ParticleDefinition(
        name, mass, width, charge, spin, parity, CConjugation,
        isospin, isospin3, GParity, type, leptonNumber, baryonNumber,
        encoding, false, 0.0, nullptr, false
    G4VDecayChannel* gammaChannel1 =
        new G4PhaseSpaceDecayChannel(ion->GetParticleName(), 0.5, 2, "gamma", "16O_3");
    G4VDecayChannel* gammaChannel2 =
        new G4PhaseSpaceDecayChannel(ion->GetParticleName(), 0.5, 2, "gamma", "16O_2");
    gammaChannel1->SetVerboseLevel(3);
    gammaChannel2->SetVerboseLevel(3);
    G4DecayTable* decayTable = new G4DecayTable();
    decayTable->Insert(gammaChannel1);
    decayTable->Insert(gammaChannel2);
    ion->SetDecayTable(decayTable);
    decayTable->DumpInfo();
    G4IonTable::GetIonTable()->Insert(ion);
And this one from ConstructProcess():
void DRAGONPhysicsList::AddExoticIonProcesses() {
      G4ParticleTable::GetParticleTable()->FindParticle("ExoticIon");
  if (!ion) {
    G4cout << "ExoticIon not found!" << G4endl;
    return;
  G4ProcessManager* pm = ion->GetProcessManager();
  if (!pm) {
    pm = new G4ProcessManager(ion);
    ion->SetProcessManager(pm);
  // ---- Multiple scattering ----
  G4hMultipleScattering* msc = new G4hMultipleScattering();
  pm->AddProcess(msc, -1, 1, 1);
  // ---- Ionisation ----
  G4ionIonisation* ionIoni = new G4ionIonisation();
  pm->AddProcess(ionIoni, -1, 2, 2);
  // ---- Nuclear stopping ----
  G4NuclearStopping* nucStop = new G4NuclearStopping();
  pm->AddProcess(nucStop, -1, 3, -1);
  G4cout << "Custom ion processes added to ExoticIon" << G4endl;
These are the only important processes I need for this user-defined ion in my simulation.
During the simulation I see:
Particle ExoticIon has a strange PDGEncoding
*** G4Exception : PART102
issued by : G4ParticleDefintion::G4ParticleDefintion
Strange PDGEncoding
G4DecayTable:  ExoticIon
0:  BR:  0.5  [Phase Space]   :   gamma 16O_3
1:  BR:  0.5  [Phase Space]   :   gamma 16O_2
G4WT0 > G4PhaseSpaceDecayChannel::DecayIt()
G4WT0 > G4PhaseSpaceDecayChannel::TwoBodyDecayIt()
G4WT0 > G4PhaseSpaceDecayChannel::TwoBodyDecayIt() - Create decay products in rest frame
G4WT0 >  ----- List of DecayProducts  -----
G4WT0 >  ------ Parent Particle ----------
G4WT0 >  Particle type - ExoticIon
G4WT0 >    mass:        50[GeV]
G4WT0 >    charge:      2[e]
G4WT0 >    Direction x: 0, y: 0, z: 0
G4WT0 >    Total Momentum = 0[GeV]
G4WT0 >    Momentum: 0[GeV], y: 0[GeV], z: 0[GeV]
G4WT0 >    Total Energy   = 50[GeV]
G4WT0 >    Kinetic Energy = 0[GeV]
G4WT0 >  MagneticMoment  [MeV/T]: 0
G4WT0 >    ProperTime     = 0[ns]
G4WT0 >  ------ Daughter Particles  ------
G4WT0 >  ----------1 -------------
G4WT0 >  Particle type - gamma
G4WT0 >    mass:        0[GeV]
G4WT0 >    charge:      0[e]
G4WT0 >    Direction x: -0.393984, y: -0.0868169, z: -0.915008
G4WT0 >    Total Momentum = 22.7781[GeV]
G4WT0 >    Momentum: -8.9742[GeV], y: -1.97752[GeV], z: -20.8421[GeV]
G4WT0 >    Total Energy   = 22.7781[GeV]
G4WT0 >    Kinetic Energy = 22.7781[GeV]
G4WT0 >  ----------2 -------------
G4WT0 >  Particle type - 16O_3
G4WT0 >    mass:        14.9061[GeV]
G4WT0 >    charge:      6[e]
G4WT0 >    Direction x: 0.393984, y: 0.0868169, z: 0.915008
G4WT0 >    Momentum: 8.9742[GeV], y: 1.97752[GeV], z: 20.8421[GeV]
G4WT0 >    Total Energy   = 27.2219[GeV]
G4WT0 >    Kinetic Energy = 12.3158[GeV]
G4WT0 >  ----- End List of DecayProducts  -----
From UserSteppingAction():
void DRAGONSteppingAction::UserSteppingAction(const G4Step* step) {
  const G4Track* track5 = step->GetTrack();
  G4ParticleDefinition* particle5 = track5->GetDefinition();
  if (particle5) {
    G4ProcessManager* processManager = particle5->GetProcessManager();
    if (processManager) {
      G4ProcessVector* processVector = processManager->GetProcessList();
      if (processVector) {
        G4cout << "Processes for particle '"
               << particle5->GetParticleName() << "':" << G4endl;
        for (size_t i = 0; i < processVector->size(); i++) {
          G4VProcess* process = (*processVector)[i];
          if (process) {
            G4cout << "  - Process " << i << ": "
                   << process->GetProcessName() << G4endl;
And during simulation I get:
Processes for particle 'ExoticIon':
  - Process 0: Transportation
  - Process 1: Decay
  - Process 2: StepLimiter
  - Process 3: UserSpecialCut
  - Process 4: msc
  - Process 5: ionIoni
  - Process 6: nuclearStopping
MY CONCERN:
I was wondering if the way I proceeded is correct and works even despite the issue that the PDG encoding does not follow the Geant4 internal structure. This might be a problem for the evaluation of the A and Z values for this ion (important for nuclear processes like nuclear stopping and others).
Thank you!
this is not something I have tried myself. With very low priority I can have a look at what you are attempting. If in the meantime you work it out, please let us know.
/Pico
