these values are normal as the starting point. Usually in Geant4 interval of stability of results versus cut in range is wide, so you may define cut in range 0.1 mm and got similar results. Recommended approach: choose the cut below smallest geometry size of your setup if you have small sensitive volumes; if you have large volumes but need to study bremsstrahlung spectrum, do not use high cut - 1 mm probably is the upper limit.
Is this what you set for /run/beamOn? I don’t know why it would have taken so long for a problem, but in any event you can’t use a number that large. The event count in Geant4 is a 32-bit signed integer (G4int), with a maximum value of 2^31-1 = ~2.4e+9.
Yes it is what I set for /run/beamOn. The problem is that when I use the next values of cuts there is no problem with core dumping and all one billion primary particles normally generated.
Have you run this interactively in the debugger? It’ll probably tie up your terminal window for a while, at the segfault you’ll be able to get a traceback, see where things failed, and inspect variables etc.
Is that mean that I principally can’t set such a small value for cuts ? Because in this case I should set the values bigger than thickness of the thinnest target in my setup. If I understand you correctly it leads to wrong results of calculation.
