DCMTK in DICOM example
I have GEANT4 v11.2 and Ubunto 22.04
I installed DCMTK in this path /home/ihssane/DCMTK/dcmtk-3.6.8-install
After I executed this command : export DCMTK_BASE_DIR = /home/ihssane/DCMTK/dcmtk-3.6.8-install
export LD_LIBRARY_PATH=${LD_LIBRARY_PATH}:${DCMTK_BASE_DIR} /lib
echo $LD_LIBRARY_PATH
/home/ihssane/ROOT/root_v6.30.02.Linux-ubuntu22.04-x86_64-gcc11.4/root/lib:/usr/lib/x86_64-linux-gnu:/usr/lib/x86_64-linux-gnu:/home/ihssane/GEANT4/geant4-v11.2.0-install/lib:/home/ihssane/GEANT4/geant4-v11.2.0-install/lib:/usr/lib/x86_64-linux-gnu::/home/ihssane/DCMTK/dcmtk-3.6.8-install/lib
And In GNUmakefile I uncomment this line #DICOM_USE_DCMTK := true, but when I do the make in the DICOM example I get this error and I can’t find the solution.
Does anyone know how to solve it?
If you want to use the GNUmake system (which is deprecated), then this requires sourcing the geant4make.sh` script present in the geant4 install first.
Otherwise, directly use the CMake system to find/generate the needed build scripts.
Thank you very much sir @bmorgan for your response.
These are the steps I followed, does this mean that the association of DCMTK with the DICOM example of GEANT4 was successful,
or I must continue the other steps mentioned in the README:
2c) CMake installation and inheriting from DICOM:
  • Set the CMAKE_INSTALL_PREFIX (typically use the same install prefix as the Geant4 distribution)
  • Install the project
  • Installation will install libraries + DICOMConfig.cmake + other config files
    • if DCMTK is enabled, will also install dicomReader library + icomReaderConfig.cmake and it’s other config files
  • In the new Geant4 application, add “find_package(DICOM REQUIRED)” to CMakeLists.txt
    • (optionally) add "set(DICOM_DIR ${Geant4_DIR} CACHE PATH “Path to DICOM installation config files”) to CMakeLists.txt
    • add "include_directories(${DICOM_INCLUDE_DIRS}) and link target to ${DICOM_LIBRARIES}
    • if DCMTK is enabled, DICOMConfig.cmake will include the DCMTK and dicomReader installations, i.e. there is not need for “find_package(dicomReader)” or “find_package(DCMTK)”
Just try running make in the directory where you ran CMake first - if it’s configured o.k. (which it has) that’s the first thing to try.
I trying to use make after CMake but i get this error again.
Right, I think you’ve run CMake and then make in the source directory of the example. That means it’s going to pick up the GNUmakefile not the generated Makefile. Try running:
$ make -f Makefile
and see if that makes a difference. See also the relevant section of the Application Developer Guide for an overview of the CMake system and how to use it.
Thanks sir @bmorgan It’s done,
But when i add this lignes :
target_link_libraries(DICOM DICOM::library ${Geant4_LIBRARIES} ${DICOM_READER_LIBRARY} ${DCMTK_LIBRARIES})
on CMakeLists.tkt as already mentioned in the README:
-In the new Geant4 application, add “find_package(DICOM REQUIRED)” to CMakeLists.txt
Then I do the cmake…/ , i have this error :
ihssane@ihssane-HP-EliteBook-840-G4:~/Bureau/DICOM$ cmake …/
CMake Error: The source directory “/home/ihssane/Bureau” does not appear to contain CMakeLists.txt.
Specify --help for usage, or press the help button on the CMake GUI.
You need to point CMake to the directory holding the CMakeLists.txt for the project - I guess this might be cmake .. rather than cmake ...?
Hi ser @bmorgan thank you sir for answering me.
My problem is that when I add these lines:
target_link_libraries(DICOM ${DICOM_LIBRARIES})
in CMakeLists.txt and I want to run example, but I believe I need to export its two commands as it is mentioned in the README:
export G4LEDATA=/home/ihssane/GEANT4/geant4-v11.2.0-install/share/Geant4/data/G4EMLOW8.5
export G4LEVELGAMMADATA=/home/ihssane/GEANT4/geant4-v11.2.0-install/share/Geant4/data/PhotonEvaporation5.7
G4LEDATA pointing to the low energy data base, is the G4EMLOW8.5 folder which corresponds to the low energy data base? But when I do cmake…/ I would get errors :
Sincerely.
I’m now a bit lost I’m afraid. Could you please try starting from scratch, so deleting the directory tree where you’ve copied the DICOM example (I assume DICOM and not DICOM2?). Re-copy it from the install area of Geant4 and do exactly the following. My comments are preceded by “#”, the commands you need to run follow the “$” sign.
# Let's assume that you've deleted and recopied DICOM to ~/Bureau/DICOM
$ cd ~/Bureau/DICOM
# double check there is NO CMakeCache.txt file is this directory, you should see the "No such message..."
$ ls CMakeCache.txt
ls: CMakeCache.txt: No such file or directory
# create a directory in which to do the build
$ mkdir build
# change into it
$ cd build
# Run CMake as follows:
$ cmake -DCMAKE_PREFIX_PATH="/home/ihssane/GEANT4/geant4-v11.2.0-install;/home/ihssane/DMCTK/dmctk-3.6.8-install" -DDICOM_USE_DMCTK=ON ..
# Build
$ make
Let’s see what that does first - please post the output here, but first please see the post on How to post code snippets
Screenshots aren’t optimal for helping with these types of issue.
Thank you very much sir for following up with me on my problem.
I followed the steps you mentioned as follows:
I copied the DICOM example again in my Office but when I do the cmake I would get the error:
ihssane@ihssane-HP-EliteBook-840-G4:~$ cd Bureau/DICOM
ihssane@ihssane-HP-EliteBook-840-G4:~/Bureau/DICOM$ ls CMakeCache.txt
ls: impossible d'accéder à 'CMakeCache.txt': Aucun fichier ou dossier de ce nom
ihssane@ihssane-HP-EliteBook-840-G4:~/Bureau/DICOM$ mkdir build
ihssane@ihssane-HP-EliteBook-840-G4:~/Bureau/DICOM$ cd build
ihssane@ihssane-HP-EliteBook-840-G4:~/Bureau/DICOM/build$ cmake -DCMAKE_PREFIX_PATH="/home/ihssane/GEANT4/geant4-v11.2.0-install;/home/ihssane/DMCTK/dmctk-3.6.8-install" -DDICOM_USE_DMCTK=ON ..
-- The C compiler identification is GNU 11.4.0
-- The CXX compiler identification is GNU 11.4.0
-- Check for working C compiler: /usr/bin/cc - skipped
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Found EXPAT: /usr/lib/x86_64-linux-gnu/libexpat.so (found suitable version "2.4.7", minimum required is "2.4.7")
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- Found XercesC: /usr/lib/x86_64-linux-gnu/libxerces-c.so (found suitable version "3.2.3", minimum required is "3.2.3")
-- Found OpenGL: /usr/lib/x86_64-linux-gnu/libOpenGL.so
-- Found Geant4: /home/ihssane/GEANT4/geant4-v11.2.0-install/lib/cmake/Geant4/Geant4Config.cmake (found version "11.2.0")
-- DICOM settings:
   - DICOM_USE_DCMTK: OFF
   - DICOM_USE_HEAD: OFF
-- Configuring done
-- Generating done
CMake Warning:
  Manually-specified variables were not used by the project:
    DICOM_USE_DMCTK
-- Build files have been written to: /home/ihssane/Bureau/DICOM/build
@bmorgan But when I followed his steps I would get this result, does this mean that the association of DCMTK to DICOM was done successfully?
ihssane@ihssane-HP-EliteBook-840-G4:~/Bureau/DICOM/build$ cmake -DGeant4_DIR=/home/ihssane/GEANT4/geant4-v11.2.0-install -DDICOM_USE_DCMTK=1 -DDCMTK_DIR=/home/ihssane/DCMTK/dcmtk-3.6.8-install /home/ihssane/Bureau/DICOM
-- DICOM: Using DCMTK
-- Trying to find DCMTK expecting DCMTKConfig.cmake
-- Trying to find DCMTK expecting DCMTKConfig.cmake - ok
-- DICOM settings:
   - DICOM_USE_DCMTK: 1
-- Configuring done
-- Generating done
ihssane@ihssane-HP-EliteBook-840-G4:~/Bureau/DICOM/build$ make
[  2%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomBeam.cc.o
[  5%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomBeamBlock.cc.o
[  8%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomBeamCompensator.cc.o
[ 10%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomBeamControlPoint.cc.o
[ 13%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomBeamDevice.cc.o
[ 16%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomBeamDevicePos.cc.o
[ 18%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomBeamDeviceRef.cc.o
[ 21%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomBeamWedge.cc.o
[ 24%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomFileCT.cc.o
[ 27%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomFileMgr.cc.o
[ 29%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomFilePET.cc.o
[ 32%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomFilePlan.cc.o
[ 35%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomFileStructure.cc.o
[ 37%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomROI.cc.o
[ 40%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomROIContour.cc.o
[ 43%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomVBeamDevice.cc.o
[ 45%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomVFile.cc.o
[ 48%] Building CXX object dicomReader/CMakeFiles/dicomReader.dir/src/DicomVFileImage.cc.o
[ 51%] Linking CXX shared library libdicomReader.so
[ 51%] Built target dicomReader
[ 54%] Building CXX object CMakeFiles/DICOM-library.dir/src/DicomActionInitialization.cc.o
[ 56%] Building CXX object CMakeFiles/DICOM-library.dir/src/DicomDetectorConstruction.cc.o
[ 59%] Building CXX object CMakeFiles/DICOM-library.dir/src/DicomEventAction.cc.o
[ 62%] Building CXX object CMakeFiles/DICOM-library.dir/src/DicomHandler.cc.o
[ 64%] Building CXX object CMakeFiles/DICOM-library.dir/src/DicomIntersectVolume.cc.o
[ 67%] Building CXX object CMakeFiles/DICOM-library.dir/src/DicomNestedParamDetectorConstruction.cc.o
[ 70%] Building CXX object CMakeFiles/DICOM-library.dir/src/DicomNestedPhantomParameterisation.cc.o
[ 72%] Building CXX object CMakeFiles/DICOM-library.dir/src/DicomPartialDetectorConstruction.cc.o
[ 75%] Building CXX object CMakeFiles/DICOM-library.dir/src/DicomPhantomParameterisationColour.cc.o
[ 78%] Building CXX object CMakeFiles/DICOM-library.dir/src/DicomPhantomZSliceHeader.cc.o
[ 81%] Building CXX object CMakeFiles/DICOM-library.dir/src/DicomPhantomZSliceMerged.cc.o
[ 83%] Building CXX object CMakeFiles/DICOM-library.dir/src/DicomPrimaryGeneratorAction.cc.o
[ 86%] Building CXX object CMakeFiles/DICOM-library.dir/src/DicomRegularDetectorConstruction.cc.o
[ 89%] Building CXX object CMakeFiles/DICOM-library.dir/src/DicomRun.cc.o
[ 91%] Building CXX object CMakeFiles/DICOM-library.dir/src/DicomRunAction.cc.o
[ 94%] Linking CXX shared library libDICOM.so
[ 94%] Built target DICOM-library
[ 97%] Building CXX object CMakeFiles/DICOM.dir/DICOM.cc.o
[100%] Linking CXX executable DICOM
[100%] Built target DICOM
ihssane@ihssane-HP-EliteBook-840-G4:~/Bureau/DICOM/build$ ./DICOM
Yep, looks to have built fine and be running well!
Thank you very much sir @bmorgan for your help. Should I stop here or continue these steps mentioned in the README section 2c).
 - Set the CMAKE_INSTALL_PREFIX (typically use the same install prefix as the Geant4 distribution)
 - Install the project
 - Installation will install libraries + DICOMConfig.cmake + other config files
   - if DCMTK is enabled, will also install dicomReader library + icomReaderConfig.cmake and it's other config files
 - In the new Geant4 application, add "find_package(DICOM REQUIRED)" to CMakeLists.txt
   - (optionally) add "set(DICOM_DIR ${Geant4_DIR} CACHE PATH "Path to DICOM installation config files") to CMakeLists.txt
   - add "include_directories(${DICOM_INCLUDE_DIRS}) and link target to ${DICOM_LIBRARIES}
There’s nothing more to do if you just want to run the example, explore its features, and/or modify it to your needs. Section 2c only applies if you wanted to develop a completely new, separate application that uses the DICOM reader. The “DICOM2” example is basically showing what to do in this case.
Okay thank you very much sir for these explanations.
