Deflection in magnetic field with zero charge heavy ion
_Geant4 Version:_11.2.1
_Operating System:_linux
_Compiler/Version:_g++ 13.1.1
_CMake Version:_3.26.4
I started to play with constant magnetic field in a dipole to simulate transport of beam.
However when i started to play around the charge state of my beam i notice that the angle did not change for heavy ion.
I did some test with lighter beam (alpha, C, Ca) and they work as expected but for heavier beam i started to get the same angle regardless of the charge. I even have deflection when i set my ion charge to 0 …
Is there a limit on mass you can transport ? why does it seems that for heavier beam we have a fix charge.
All transport are done in G4_galactic.
If someone as an insight it would be helpful i am stuck
How are you setting the charge? Are you varying the kinetic energy with heavier ions and how? The rigidity is inversely proportional to momentum and this decreases with a fixed E total for example.
I am setting it using the gps as so
/gps/particle ion
/gps/ion 95 243 0 0
/gps/pos/type Beam
/gps/pos/centre 0 5. -685.5 mm
/gps/pos/sigma_x 2.0 mm
/gps/pos/sigma_y 2.0 mm
/gps/direction 0 0 1
/gps/ene/type Gauss
/gps/ene/mono 104 MeV
/gps/ene/sigma 3.9 MeV
And even with a charge of 0 i get deviation by the magnetic field.
I try with different ion and up to Ca i get expected behavior, but for heavier ion i first get 2 path: one straight and one at an angle … and then at higher mass i only get the deviated one
Make sure you have
Without this it draws only the beginning and end points of a step. In between, the track might have lots of curvature. With the above, intermediate points are drawn too, and you get a nice trajectory.
I have smooth trajectory already
my main issue is that i get bending in magnetic field even when i put my beam with a neutral charge
I check the charge in vaccum in my stepping action and it even when i put it a 0 in my gps i get non zero charge using G4DynamicParticle::GetCharge()
After deeper analysis the real problem comes from the fact that the charge is being change affecting the transport. Without ionization process i get the correct transport, but now need to understand why G4Galactic is changing the charge..
