Hello, in my simulations I used SetParticleMomentum from G4ParticleGun so far, but I realized that I get different results if I use SetParticleEnergy. So I wanted to ask what’s the actual difference between these two because I couldn’t find an answer in the documentation.
in this case the source code will help you out:
https://apc.u-paris.fr/~franco/g4doxy/html/classG4ParticleGun.html#05b8603b6240f4ae9e31075cc07fd0fd
the difference is for massive particles:
particle_momentum = aMomentum;
particle_energy = std::sqrt(particle_momentum*particle_momentum+mass*mass)-mass;
OK, that solves my problem. Thank you very much
