Dear Geant4 experts,
When I statistic the deposited energy of alpha particle in water, I find there is different between “SensitiveDetector” and “Socre” methods.
In SensitiveDetector::ProcessHits(G4Step* step, G4TouchableHistory*)
Run* fRun = static_cast<Run*>(G4RunManager::GetRunManager()->GetNonConstCurrentRun());
G4ThreeVector position = step->GetPreStepPoint()->GetPosition();
G4double posZ = position.getZ();
G4double edep = step->GetTotalEnergyDeposit();
G4double weight = step->GetTrack()->GetWeight();
fRun->AddEdep(posZ, edep*weight);
return true;
In run.mac with score methods
/score/create/boxMesh mesh
/score/mesh/boxSize 25 25 25 um
/score/mesh/nBin 1 1 50
/score/mesh/translate/xyz 0 0 25 um
/score/quantity/energyDeposit doseDep
/score/close
/score/dumpAllQuantitiesToFile mesh edep.txt
The result is print here.
The result of ‘score’ methods is a smooth cure. Whlie there is a peak in the ‘sensitive’ methods.
Regards
Max
