Different results Windows vs MacOS
I have been running a project on a windows stationary computer using Geant4 v-11.3.0 with everything working fine. I wanted to also run the simulation on my personal laptop, a MacBook. I downloaded the same version of Geant4 and copied over my project folder, the installation was successful and I was able to build the project on my laptop, however the results I seem to get are different (I am measuring the SEE yield from a tungsten slab, it is almost double on my MacBook). I am wondering what could possibly be causing this difference in results, as all I did was install Geant4 and copy over the identical project folder. Any help would be much appreciated! Thanks
I’ve moved this to the Physics category, but could you post what physics list and any settings you are using, or if not a builtin one, the code for it please?
Have you built Geant4 on the Windows and Mac with the same configuration options?
Hi, I am using the MircoElec physics list that was made in the electromagnetic examples, I will show below:
#include “physicsMicroElecNew.hh”
#include “G4SystemOfUnits.hh”
// Geant4-MicroElec MODELS
#include “G4MicroElecElastic.hh”
#include “G4MicroElecElasticModel_new.hh”
#include “G4MicroElecInelastic.hh”
#include “G4MicroElecInelasticModel_new.hh”
#include “G4MicroElecLOPhononScattering.hh”
#include “G4MicroElecLOPhononModel.hh”
#include “G4MicroElecSurface.hh”
#include “G4LossTableManager.hh”
#include “G4EmConfigurator.hh”
#include “G4VEmModel.hh”
#include “G4DummyModel.hh”
#include “G4CoulombScattering.hh”
#include “G4eIonisation.hh”
#include “G4hIonisation.hh”
#include “G4ionIonisation.hh”
#include “G4eMultipleScattering.hh”
#include “G4hMultipleScattering.hh”
#include “G4BraggModel.hh”
#include “G4BraggIonModel.hh”
#include “G4BetheBlochModel.hh”
#include “G4UrbanMscModel.hh”
#include “G4MollerBhabhaModel.hh”
#include “G4IonFluctuations.hh”
#include “G4UniversalFluctuation.hh”
#include “G4PhotoElectricEffect.hh”
#include “G4RayleighScattering.hh”
#include “G4ComptonScattering.hh”
#include “G4PenelopeComptonModel.hh”
#include “G4PenelopePhotoElectricModel.hh”
#include “G4PenelopeRayleighModel.hh”
#include “G4eBremsstrahlung.hh”
#include “G4PenelopeBremsstrahlungModel.hh”
#include “ElectronCapture.hh”
#include “G4UAtomicDeexcitation.hh”
//…oooOO0OOooo…oooOO0OOooo…oooOO0OOooo…oooOO0OOooo…
MicroElecPhysics::MicroElecPhysics() : G4VUserPhysicsList()
defaultCutValue = 1 * micrometer;
cutForGamma = defaultCutValue;
cutForElectron = defaultCutValue;
cutForPositron = defaultCutValue;
cutForProton = defaultCutValue;
//G4ProductionCutsTable::GetProductionCutsTable()->SetEnergyRange(5 * eV, 10 * MeV);
SetVerboseLevel(1);
MicroElecPhysics::~MicroElecPhysics() {}
void MicroElecPhysics::ConstructParticle()
ConstructBosons();
ConstructLeptons();
ConstructBarions();
void MicroElecPhysics::ConstructBosons()
// gamma
G4Gamma::GammaDefinition();
void MicroElecPhysics::ConstructLeptons()
// leptons
G4Electron::ElectronDefinition();
G4Positron::PositronDefinition();
void MicroElecPhysics::ConstructBarions()
// baryons
G4Proton::ProtonDefinition();
G4GenericIon::GenericIonDefinition();
void MicroElecPhysics::ConstructProcess()
AddTransportation();
ConstructEM();
ConstructGeneral();
void MicroElecPhysics::ConstructEM()
G4EmParameters* param = G4EmParameters::Instance();
// param->SetDefaults();
param->SetBuildCSDARange(true);
// param->SetMscStepLimitType(fUseSafetyPlus);
// param->SetMscStepLimitType(fUseDistanceToBoundary);
param->SetMscStepLimitType(fUseSafety);
param->RegionsMicroElec();
// physicList ISS
param->SetMinEnergy(0.1 * eV);
param->SetMaxEnergy(10 * TeV);
param->SetLowestElectronEnergy(0 * eV); //<— Energie de cut dans le vide!!! A fixer 0eV pour ne pas fausser les SEY
param->SetNumberOfBinsPerDecade(20);
param->ActivateAngularGeneratorForIonisation(true);
param->SetAugerCascade(true); //*/
auto particleIterator = GetParticleIterator();
particleIterator->reset();
while ((particleIterator)()) {
G4ParticleDefinition
particle = particleIterator->value();
G4ProcessManager* pmanager = particle->GetProcessManager();
G4String particleName = particle->GetParticleName();
// 1) Processes for the World region
if (particleName == "e-") {
  // STANDARD msc is active in the world
  G4eMultipleScattering* msc = new G4eMultipleScattering();
  msc->AddEmModel(1, new G4UrbanMscModel());
  pmanager->AddProcess(msc, -1, 1, -1);
  // STANDARD ionisation is active in the world
  G4eIonisation* eion = new G4eIonisation();
  pmanager->AddProcess(eion, -1, 2, 2);
  // MicroElec elastic is not active in the world
  // G4MicroElecElasticCorrected* theMicroElecElasticProcess = new
  // G4MicroElecElasticCorrected("e-_G4MicroElecElastic");
  // theMicroElecElasticProcess->SetEmModel(new G4DummyModel(),1);
  // pmanager->AddDiscreteProcess(theMicroElecElasticProcess);
  G4MicroElecElastic* theMicroElecElasticProcess =
    new G4MicroElecElastic("e-_G4MicroElecElastic");
  theMicroElecElasticProcess->SetEmModel(new G4DummyModel(), 1);
  // G4MicroElecElasticModel_new* mod = new G4MicroElecElasticModel_new();
  // theMicroElecElasticProcess->AddEmModel(0,mod);
  // MicroElec ionisation is not active in the world
  /*G4MicroElecInelastic* microelecioni = new G4MicroElecInelastic("e-_G4MicroElecInelastic");
  microelecioni->SetEmModel(new G4DummyModel(),1);
  pmanager->AddDiscreteProcess(microelecioni);*/
  G4MicroElecInelastic* microelecioni = new G4MicroElecInelastic("e-_G4Dielectrics");
  microelecioni->SetEmModel(new G4DummyModel(), 1);
  // Phonons for SiO2
  G4MicroElecLOPhononScattering* opticalPhonon =
    new G4MicroElecLOPhononScattering("e-_G4LOPhononScattering");
  opticalPhonon->SetEmModel(new G4DummyModel(), 1);
  pmanager->AddDiscreteProcess(opticalPhonon);
  /*G4LOPhononScattering* LO60 = new G4LOPhononScattering("e-_G4LO60");
  LO60->SetEmModel(new G4DummyModel(), 1);
  pmanager->AddDiscreteProcess(LO60);//*/
  G4MicroElecSurface* MicroElecSurf = new G4MicroElecSurface("e-_G4MicroElecSurface");
  MicroElecSurf->SetProcessManager(pmanager);
  pmanager->AddDiscreteProcess(MicroElecSurf);  //*/
  ElectronCapture* ecap = new ElectronCapture("Target", 0.9 * eV);  //<--- Piges pour Al2O3
  pmanager->AddDiscreteProcess(ecap);  //*/
else if (particleName == "proton") {
  /*G4hMultipleScattering* msc = new G4hMultipleScattering();
  pmanager->AddProcess(msc, -1, 1, -1);*/
  G4hIonisation* hion = new G4hIonisation();
  pmanager->AddProcess(hion, -1, 2, 2);
  // Dielectric ionisation is not active in the world
  G4MicroElecInelastic* dielectricioni = new G4MicroElecInelastic("p_G4Dielectrics");
  dielectricioni->SetEmModel(new G4DummyModel(), 1);
  // dielectricioni->SetEmModel(new G4DummyModel(),2);
  pmanager->AddDiscreteProcess(dielectricioni);
else if (particleName == "alpha") {
  G4ionIonisation* hion = new G4ionIonisation();
  G4MicroElecInelastic* dielectricioni = new G4MicroElecInelastic("alpha_G4Dielectrics");
  dielectricioni->SetEmModel(new G4DummyModel(), 2);
else if (particleName == "GenericIon") {
  pmanager->AddProcess(new G4hMultipleScattering, -1, 1, -1);*/
  /*G4CoulombScattering* cs = new G4CoulombScattering();
  cs->AddEmModel(0, new G4IonCoulombScatteringModel());
  cs->SetBuildTableFlag(false);
  pmanager->AddDiscreteProcess(cs);*/
  // Dielectric ionisation is not actived in the world
  G4MicroElecInelastic* dielectricioni = new G4MicroElecInelastic("ion_G4Dielectrics");
// 2) Define processes for Target region
// STANDARD EM processes should be inactivated when corresponding MicroElec processes are used
// - STANDARD EM e- processes are inactivated below 100 MeV
// - STANDARD EM proton & ion processes are inactivated below standEnergyLimit
G4EmConfigurator* em_config = G4LossTableManager::Instance()->EmConfigurator();
G4VEmModel* mod;
// *** e-
// —> STANDARD EM processes are inactivated below 100 MeV
G4UrbanMscModel* msc = new G4UrbanMscModel();
msc->SetActivationLowEnergyLimit(100 * MeV);
em_config->SetExtraEmModel(“e-”, “msc”, msc, “Target”);
mod = new G4MollerBhabhaModel();
mod->SetActivationLowEnergyLimit(10 * MeV);
em_config->SetExtraEmModel(“e-”, “eIoni”, mod, “Target”, 0.0, 10 * TeV,
new G4UniversalFluctuation());
// —> MicroElec processes activated
em_config->SetExtraEmModel(“e-”, “e-_G4MicroElecElastic”, mod, “Target”, 0.1 * eV, 100 * MeV);
mod = new G4MicroElecInelasticModel_new();
em_config->SetExtraEmModel(“e-”, “e-_G4Dielectrics”, mod, “Target”, 0.1 * eV, 10 * MeV);
// G4double hw = 0.15*eV;
// Old phonon
/mod = new LOPhononModel(0.153eV,false);
em_config->SetExtraEmModel(“e-”, “e-_G4LOPhononScattering”, mod, “Target”, 0.153*eV, 10 * MeV);
mod = new LOPhononModel(0.063eV,false);
em_config->SetExtraEmModel(“e-”, “e-_G4LO60”, mod, “Target”, 0.06
eV, 10 * MeV);//*/
// Phonons LO pour sio2 et al2o3
mod = new G4MicroElecLOPhononModel();
//mod->SetActivationLowEnergyLimit(5 * eV);
em_config->SetExtraEmModel(“e-”, “e-_G4LOPhononScattering”, mod, “Target”, 0.1 * eV,
10 * MeV); //*/
// *** proton ----------------------------------------------------------
// —> STANDARD EM processes inactivated below standEnergyLimit
// STANDARD msc is still active
// Inactivate following STANDARD processes
// il faut desactiver Bragg puisque notre modle descend en-dessous de 50 keV
/mod = new G4BraggModel();
mod->SetActivationHighEnergyLimit(50
keV);
em_config->SetExtraEmModel(“proton”,“hIoni”,mod,“Target”,0.0,2MeV, new G4IonFluctuations());/
mod = new G4BetheBlochModel();
em_config->SetExtraEmModel(“proton”, “hIoni”, mod, “Target”, 2 * MeV, 10 * TeV,
// —> Dielectric processes activated
mod->SetActivationLowEnergyLimit(100 * eV);
em_config->SetExtraEmModel(“proton”, “p_G4Dielectrics”, mod, “Target”, 100 * eV, 10 * MeV);
// em_config->SetExtraEmModel(“proton”,“p_G4Dielectrics”,new G4DummyModel,“Target”,10MeV,10TeV);
// *** alpha ----------------------------------------------------------
em_config->SetExtraEmModel(“alpha”, “ionIoni”, mod, “Target”, 10 * MeV, 10 * TeV,
/mod = new G4MicroElecInelasticModel_new();
//mod->SetActivationLowEnergyLimit(100
eV);
em_config->SetExtraEmModel(“alpha”,“alpha_G4Dielectrics”,mod,“Target”,0.0,10MeV);///
// *** ion ----------------------------------------------------------
/mod = new G4BraggIonModel();
keV);
em_config->SetExtraEmModel(“GenericIon”,“ionIoni”,mod,“Target”,0.0,2MeV, new
em_config->SetExtraEmModel(“GenericIon”, “ionIoni”, mod, “Target”, 10 * MeV, 10 * TeV,
em_config->SetExtraEmModel(“GenericIon”, “ion_G4Dielectrics”, mod, “Target”, 0.0, 10 * MeV);
// em_config->SetExtraEmModel(“GenericIon”,“ion_G4Dielectrics”,new
// G4DummyModel,“Target”,10GeV,10TeV);
// Deexcitation
G4VAtomDeexcitation* de = new G4UAtomicDeexcitation();
G4LossTableManager::Instance()->SetAtomDeexcitation(de);
de->SetFluo(true);
de->SetAuger(true);
de->SetPIXE(true);
de->InitialiseForNewRun();
// G4ProductionCutsTable::GetProductionCutsTable()->SetEnergyRange(5eV, 100.0GeV);
void MicroElecPhysics::ConstructGeneral() {}
void MicroElecPhysics::SetCuts()
if (verboseLevel > 0) {
G4cout << “MicroElecPhysics::SetCuts:”;
G4cout << "CutLength : " << G4BestUnit(defaultCutValue, “Length”) << G4endl;
// set cut values for gamma at first and for e- second and next for e+,
// because some processes for e+/e- need cut values for gamma
SetCutValue(cutForGamma, “gamma”);
SetCutValue(cutForElectron, “e-”);
SetCutValue(cutForPositron, “e+”);
SetCutValue(cutForProton, “proton”);
if (verboseLevel > 0) { DumpCutValuesTable(); }
When I build with the cmake gui, for both I have ticked the multithreaded and install data, as well as the open gl option. There is also a box that gets automatically ticked on Mac which is GEANT4_USE_SYSTEM_EXPAT, but I am not sure if that made a difference.
